I have a 2002 V35 gt8 with a fried BCM, when ignition on no headlights or wipers, when ignition off and car locked wipers working and headlight flickering.
Have obtained a new BCM from Nissan but after booking in to get it fitted (waiting a week), and a couple of hours in their service bay to be told that "we can't program it".rant.gif
Contacted another Nissan dealership to be told "We dont do a lot of imports and were not setup to do that sort of thing"
My question is, has anyone had to program one, if you were successful, who and where?cheers.gif
https://www.sau.com.au/forums/topic/393601-v35-bcm/
http://www.nicoclub.com/FSM/G35/Sedan/2003/bcs.pdf
FSM for a 2003 G35 Sedan- Body Control systems
I know its not your car, but might help somewhat... I hate that reply from Stealerships. Couldn't see anything in there that states that it has to be programmed. Chris Rogers would be the person to go to for info. Seems to be the Guru for Nissan electrical eccentricities.
Hope it gets sorted!
https://www.sau.com.au/forums/topic/393601-v35-bcm/#findComment-6260269
Ahh- did see something- right at the end.
When replacing BCM perform initialization of NATS system and registration of all NATS ignition key IDs.
Thats the Nissan Anti theft system (NATS), and your key fobs. Should be an easy thing to do through Consult. Tell them exactly what you want at the dealership- then watch them embarrass themselves. They might get it right too.
https://www.sau.com.au/forums/topic/393601-v35-bcm/#findComment-6260278
They don't want to listen to what I say, they know best, thats why the have that logo out the front, which also matches the one on their shirt.
I have already embarrassed the service manager there already when I took my car down their to get the consult put on it to test the BCM. He didn't want to do it saying that "I don't want to hook it up for half an hour and have to charge you $50 and have no result"
He eventually conceded and hooked it up, when returning the car to me with the printout, showing a fault in the ABS that cleared straight away and one in the TCU which wouldn't clear, I asked how much, he replied "don't worry about it" choking on humble piesick.gif.
Fault with TCU was a brake switch fault. Nissan response "we don't know where that is, on the outside, on the inside, we have no manual"
Contacted CVT.CO.NZ and the first line that I got back in response was "They don't know what the are doing", there is no brake switch on the gearbox.whistling.gif
This is the kind of "expertise" I have to deal with when I go near the place, they get upset when you tell them they are wrong, bitch up when you prove that they are wrong, then they bullsh*t you till you walk away holding your head, IN PAIN.
https://www.sau.com.au/forums/topic/393601-v35-bcm/#findComment-6260791
What Nissan dealer did u goto?
https://www.sau.com.au/forums/topic/393601-v35-bcm/#findComment-6261203
whilst I have a scan tool that can read these cars and program keys to them the main point of it is the immobiliser codes.
if you do not have those then you are wasting your money. you need to see someone with a C2, C3, carmen scan OR a launch X431 full size unit. all of them will recode the car but with out the imobiliser code you are pretty much screwed. nissan are the only ones that can do that. sending an email to nissan japan is OUT as they will refer it back to nissan oz. FTG nissan would be my pick of the dealers. they do GTR and seemed quite helpful when I took imports there for key work.
start there.
https://www.sau.com.au/forums/topic/393601-v35-bcm/#findComment-6261387
http://www.nicoclub....an/2003/bcs.pdf
that is 'close' but not the same as the keys are different and they run an external calsonic remote fob.
https://www.sau.com.au/forums/topic/393601-v35-bcm/#findComment-6261393
So the Consult units will allow for a recode but only with an immobiliser code as well. I'm guessing what makes Nissan capable of performing it regardless is the fact that they have the immobiliser security card which does not require the original codes to allow for this. Would I be right in saying that?
https://www.sau.com.au/forums/topic/393601-v35-bcm/#findComment-6263541
Correct.
I'm guessing what makes Nissan capable of performing it regardless is the fact that they have a way to derive immobiliser security card which does not require the original codes to allow for this. Would I be right in saying that?
corrected for future reading.
nissan can look up ( and they have done so for me.) the codes but they NEED the car to look it up.
finding a dealership to help isnt too bad BUT if you come across like a d1ck telling them you know everything about your car (and they know nothing ) then expect to be blown off.
not saying thats what the OP did but it does happen.
I seem to remember a key code program floating about that did the calc off a checksum. may be worth having a dig on this forum for it under spare keys.
you will STILL need a C2/C3 to do it. my diagun will program certain aspects of it but a C2/C3 is a FAR better option.
https://www.sau.com.au/forums/topic/393601-v35-bcm/#findComment-6263817
I see. I was preparing myself for the worst, thinking perhaps the Fly Company in China with their Consult 4 unit and security cards would be the failsafe for me in case if I didn't get any co-operation out of my local dealers. I did get a tiny little metal tag attached to my transponder key which has 5 digits stamped into it. After doing some reading up on NATS and the various incarnations of it, I think that could be my immobiliser code so I'm glad I made a point of keeping everything that came with my V36 recently in a safe place.
Thanks for the prompt response, as always!
https://www.sau.com.au/forums/topic/393601-v35-bcm/#findComment-6264150
  • 6 months later...
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
