http://news.drive.co...122566#comments
To-day's update of a 8/7/11 Article suggests that Nissan has a budget to reproduce Datsuns again.
Besides the Chinese market, I would suggest that Nissan bring back some low budget fun into motoring with a Datsun to compete against 'Toymota'
In fact I've posted such a comment for vetting, as some of you might...
So far in this morning's poll, 66% support Datsun's re-emergence.
My Q here on SAU is...
What would you like to see in a Datsun engine bay + suspension and brakes etc?
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/
I think I would soil the front of my pants if they revived Datsun.
Imagine a modern day 1600. I'm getting goose bumps just thinking about it.
I want small (<1000kg) rwd 4 door, boxy shape and a banshee revving, quad throttle bodied, all alloy 1.6L 4 cylinder.
16 inch wheels, independent suspension at each corner, old school trailing arm out back with some geometry correction as is generally applied to 1600s now, very basic interior. Strip away as many electronics as legally possible, only two airbags.
280ishmm brakes with twin piston callipers up front and smaller single pistons out back.
R180 LSD diff, big sway bars.
Fuel tank underslung, a can of tyre goo instead of a spare and a boot mounted battery.
Chrome bumper bars, door handles and c-pillar vents. A Venetian blind in the back window.
Please Datsun, do it for me. Without doubt I would buy one on pre-order. A new 1600 is a dream come true for me.
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6261782
Not sure if they could get away with the weight savings needed and still comply with modern safety requirements, without going the super expensive materials route.
Most requirements are simple sensors and an ECU capable of doing what it has to. There are no requirements for a car to have super dooper intrusion protection, 20 airbars and all that crap. The only mandatory requirement is ESC.
A 5 door Hyundai Getz weighs barely over a ton, so it's not hard to keep kerb weight down cheaply. The original 1600 (with iron blocked L16 and full sized spare) was 900kgs, so add 100kg worth of modern shit to it if you must. That should be more than enough to appease the safetycrats.
GIMMIE!
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6261934
Amen.
My dream version would be something like (obviously using modern bits and to keep it cheap):
- Small light weight sedan, coupe, ute, wagon - say roughly the dimentions of a modern Yaris sedan
- RWD
- 1.6L to 2L alloy engine with direct injection, with an option for a low boost turbo setup.
- 6 speed manual from an S15 (light weight tranny)
- 5 speed auto option with tiptronic from 350z (still keeping it light weight)
- Minimal sound insulation (keep it light and cheap), but with option for people that want it.
- All alloy components where possible and plastic to reduce weight and cost
- Front and side airbags (whatever the minimum to meet regs.)
- VDC, TCS and ABS etc... (whatever the minimum to meet regs.)
- Brakes from R34 non-turbo (aka Maxima/300zx brakes)
- R200 LSD
- Basic interior with A/C
- Manual window winders, with an option for electirc windows if people so desire
- Premium sounding 2 speaker audio setup, with Single DIN AM/FM, aux in, DAB+ and USB - no need for CD, extra speakers or subs.
- No other un-needed electrics.
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6263609
No one in their right mind would "expect" the car I've described, or anything similar, but it's fun to dream.
You've only got to click the link in Terry's opening post to know what to expect; a rebadged POS front drive budget mobile.
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6264446
Yeh - true. Wishes will remain wishes...
At the same time the S chassis (S15) would be good to bring back especially since all the R&D has been done. Maybe find ways to make it cheaper/lighter and put a different shell, engine and safety features to suit. Profit!
They jam enough equipment into your typical Toyota Yaris/Mazda 2/Nissan Micra
I'd rather a pov spec RWD car anytime :cheers:
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6265037
    • Yea I could, but it is amusing how shit a stock seat and belt are
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
