http://news.drive.co...122566#comments
To-day's update of a 8/7/11 Article suggests that Nissan has a budget to reproduce Datsuns again.
Besides the Chinese market, I would suggest that Nissan bring back some low budget fun into motoring with a Datsun to compete against 'Toymota'
In fact I've posted such a comment for vetting, as some of you might...
So far in this morning's poll, 66% support Datsun's re-emergence.
My Q here on SAU is...
What would you like to see in a Datsun engine bay + suspension and brakes etc?
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/
I think I would soil the front of my pants if they revived Datsun.
Imagine a modern day 1600. I'm getting goose bumps just thinking about it.
I want small (<1000kg) rwd 4 door, boxy shape and a banshee revving, quad throttle bodied, all alloy 1.6L 4 cylinder.
16 inch wheels, independent suspension at each corner, old school trailing arm out back with some geometry correction as is generally applied to 1600s now, very basic interior. Strip away as many electronics as legally possible, only two airbags.
280ishmm brakes with twin piston callipers up front and smaller single pistons out back.
R180 LSD diff, big sway bars.
Fuel tank underslung, a can of tyre goo instead of a spare and a boot mounted battery.
Chrome bumper bars, door handles and c-pillar vents. A Venetian blind in the back window.
Please Datsun, do it for me. Without doubt I would buy one on pre-order. A new 1600 is a dream come true for me.
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6261782
Not sure if they could get away with the weight savings needed and still comply with modern safety requirements, without going the super expensive materials route.
Most requirements are simple sensors and an ECU capable of doing what it has to. There are no requirements for a car to have super dooper intrusion protection, 20 airbars and all that crap. The only mandatory requirement is ESC.
A 5 door Hyundai Getz weighs barely over a ton, so it's not hard to keep kerb weight down cheaply. The original 1600 (with iron blocked L16 and full sized spare) was 900kgs, so add 100kg worth of modern shit to it if you must. That should be more than enough to appease the safetycrats.
GIMMIE!
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6261934
Amen.
My dream version would be something like (obviously using modern bits and to keep it cheap):
- Small light weight sedan, coupe, ute, wagon - say roughly the dimentions of a modern Yaris sedan
- RWD
- 1.6L to 2L alloy engine with direct injection, with an option for a low boost turbo setup.
- 6 speed manual from an S15 (light weight tranny)
- 5 speed auto option with tiptronic from 350z (still keeping it light weight)
- Minimal sound insulation (keep it light and cheap), but with option for people that want it.
- All alloy components where possible and plastic to reduce weight and cost
- Front and side airbags (whatever the minimum to meet regs.)
- VDC, TCS and ABS etc... (whatever the minimum to meet regs.)
- Brakes from R34 non-turbo (aka Maxima/300zx brakes)
- R200 LSD
- Basic interior with A/C
- Manual window winders, with an option for electirc windows if people so desire
- Premium sounding 2 speaker audio setup, with Single DIN AM/FM, aux in, DAB+ and USB - no need for CD, extra speakers or subs.
- No other un-needed electrics.
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6263609
No one in their right mind would "expect" the car I've described, or anything similar, but it's fun to dream.
You've only got to click the link in Terry's opening post to know what to expect; a rebadged POS front drive budget mobile.
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6264446
Yeh - true. Wishes will remain wishes...
At the same time the S chassis (S15) would be good to bring back especially since all the R&D has been done. Maybe find ways to make it cheaper/lighter and put a different shell, engine and safety features to suit. Profit!
They jam enough equipment into your typical Toyota Yaris/Mazda 2/Nissan Micra
I'd rather a pov spec RWD car anytime :cheers:
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6265037
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
