http://news.drive.co...122566#comments
To-day's update of a 8/7/11 Article suggests that Nissan has a budget to reproduce Datsuns again.
Besides the Chinese market, I would suggest that Nissan bring back some low budget fun into motoring with a Datsun to compete against 'Toymota'
In fact I've posted such a comment for vetting, as some of you might...
So far in this morning's poll, 66% support Datsun's re-emergence.
My Q here on SAU is...
What would you like to see in a Datsun engine bay + suspension and brakes etc?
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/
I think I would soil the front of my pants if they revived Datsun.
Imagine a modern day 1600. I'm getting goose bumps just thinking about it.
I want small (<1000kg) rwd 4 door, boxy shape and a banshee revving, quad throttle bodied, all alloy 1.6L 4 cylinder.
16 inch wheels, independent suspension at each corner, old school trailing arm out back with some geometry correction as is generally applied to 1600s now, very basic interior. Strip away as many electronics as legally possible, only two airbags.
280ishmm brakes with twin piston callipers up front and smaller single pistons out back.
R180 LSD diff, big sway bars.
Fuel tank underslung, a can of tyre goo instead of a spare and a boot mounted battery.
Chrome bumper bars, door handles and c-pillar vents. A Venetian blind in the back window.
Please Datsun, do it for me. Without doubt I would buy one on pre-order. A new 1600 is a dream come true for me.
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6261782
Not sure if they could get away with the weight savings needed and still comply with modern safety requirements, without going the super expensive materials route.
Most requirements are simple sensors and an ECU capable of doing what it has to. There are no requirements for a car to have super dooper intrusion protection, 20 airbars and all that crap. The only mandatory requirement is ESC.
A 5 door Hyundai Getz weighs barely over a ton, so it's not hard to keep kerb weight down cheaply. The original 1600 (with iron blocked L16 and full sized spare) was 900kgs, so add 100kg worth of modern shit to it if you must. That should be more than enough to appease the safetycrats.
GIMMIE!
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6261934
Amen.
My dream version would be something like (obviously using modern bits and to keep it cheap):
- Small light weight sedan, coupe, ute, wagon - say roughly the dimentions of a modern Yaris sedan
- RWD
- 1.6L to 2L alloy engine with direct injection, with an option for a low boost turbo setup.
- 6 speed manual from an S15 (light weight tranny)
- 5 speed auto option with tiptronic from 350z (still keeping it light weight)
- Minimal sound insulation (keep it light and cheap), but with option for people that want it.
- All alloy components where possible and plastic to reduce weight and cost
- Front and side airbags (whatever the minimum to meet regs.)
- VDC, TCS and ABS etc... (whatever the minimum to meet regs.)
- Brakes from R34 non-turbo (aka Maxima/300zx brakes)
- R200 LSD
- Basic interior with A/C
- Manual window winders, with an option for electirc windows if people so desire
- Premium sounding 2 speaker audio setup, with Single DIN AM/FM, aux in, DAB+ and USB - no need for CD, extra speakers or subs.
- No other un-needed electrics.
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6263609
No one in their right mind would "expect" the car I've described, or anything similar, but it's fun to dream.
You've only got to click the link in Terry's opening post to know what to expect; a rebadged POS front drive budget mobile.
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6264446
Yeh - true. Wishes will remain wishes...
At the same time the S chassis (S15) would be good to bring back especially since all the R&D has been done. Maybe find ways to make it cheaper/lighter and put a different shell, engine and safety features to suit. Profit!
They jam enough equipment into your typical Toyota Yaris/Mazda 2/Nissan Micra
I'd rather a pov spec RWD car anytime :cheers:
https://www.sau.com.au/forums/topic/393753-d-a-t-s-u-n/#findComment-6265037
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
