Now, I also have some cosmetic updates as well. Neither of these projects are actually completed yet, but I will post photos of where they are up to.
First of all, I decided to respray my front bar. 2 years of being about 30mm off the ground had taken their toll, and I also wanted to modify it a little bit. First up, I cleared around the damaged areas with an angle grinder to give the new fibreglass something to grip to:
528400_10151347788272541_1702785532_n.jp
551388_10151347788747541_1825082946_n.jp
Doing this actually revealed how poor quality these cheap copy front bars actually are. This one is actually so full of bog rather than fibreglass, it really is very poor. Time to make it a bit better!
I actually wanted to build a lip up around the inside of the bottom of the bar, simply to give me something to screw into so I can install a front diffuser later on. So first I wet up where I wanted to build the lip:
393044_10151354898997541_1290511130_n.jp
I then layed up 5 layers of 6oz fibreglass cloth.
This is it after curing:
405892_10151354900032541_1953804814_n.jp
Also patched up the damaged bits in the process
601868_10151354900627541_2099483694_n.jp
I then cleaned it all up a bit using a rotary tool
946133_10151354900887541_1910088597_n.jp
941834_10151354901227541_1588018021_n.jp
302767_10151356852817541_1529291567_n.jp
And then these mounting tabs on top of the bar had actually giving me quite a lot of trouble in the past, being very flimsy they were always snapping off. Enter 4 layers of carbon fibre
946703_10151356853557541_1845705797_n.jp
Like to see ya snap off now ya jerks :glare:
I am now in the process of smoothing it all out more and getting it ready for paint. This is where it was at after the first coat of filler-primer last night:
941569_10151356854247541_1860576328_n.jp
But wait, there's more!
This project was a bit of fun really, but something I have wanted to do for a long time. Standard GT non-xenon headlights, extra condensation:
316000_10151356854757541_2045553658_n.jp
Place in oven at 100 degrees for 8 minutes or until crispy and golden!
164935_10151356855332541_2089819668_n.jp
All disassembled:
945058_10151356856012541_1186237108_n.jp
Will give this a good polish while it's off!
Now for the main course. I want to take this:
And fit it inside the stock reflector, like so:
270895_10151356857497541_2030138816_n.jp
Which will require a bit of this:
But first! I need to do this:
944567_10151356858842541_1558664707_n.jp
Bit of dremel work gives me this!
931207_10151356859132541_1084247380_n.jp
Rinse and repeat
936291_10151356859922541_1060488310_n.jp
944497_10151356860177541_1133914271_n.jp
That is as far as I have gotten with those. Undecided how I'm going to finish them, but I think I will paint the stock reflector and E46-R shroud satin black. I was going to paint the cut-off shield behind the projector red to give it a very aggressive look, like this (credit for this work goes to EvoXenon)
but I don't think I will do that. I wanted a classier look, not necessarily a more aggressive look. I don't think the red would suit my car very well.
That's almost more aggressive than red! Haha. Does look awesome though. I think I'll just leave them clear for now and see how it all looks put together. If I don't like it I can paint it, but if I paint it and don't like it then I'm pretty screwed.
Shinobi how's are your headlights going? Does the paint cope with the heat ok? Do you get any bits of light coming out from the side reflector next to the projector? I sorta suspect these projectors will leak a bit of light out the sides, trying to figure out how to seal them. Might chat to Steve again.
Edited by Hanaldo
Hmm maybe try a lighter colour like a turquoise or something.
The headlights are all finished and on my car now and work a treat. Light output is so much better!
Yeah the paint is still fine. Just make sure it's high temp that you paint it with. My projectors are mounted a little further back so the shroud can sit flush with the reflector. And cause of that the only light that you see is the light coming out of the projector.
I'll try get EvoXenon in on here so he can share some of his insight
Edited by shinobi_s14
Sprayed them satin black last night, takes the chrome edge off them, makes them look a bit more factory I think. I like them. With any luck I should get them finished today or tomorrow.
Well they are done and ready to go on the car. But I've just finished spraying my front bar and some other bits, so the car is currently covered up. Don't want to risk putting dust in the air by moving anything, so I won't do any more tonight. But everything should be done in the next couple of days!
So, car is finally all finished. Spent today wiring the bi-xenons and then tucking the headlight wiring to neaten things up, 4 HID ballast gets pretty messy! Looks much better now. Also decided to remove the eyelids. Anyway, some photos:
First, another one of the front bar:
Another thing I fixed up while I was at it, some of you might remember this damage I picked up at Powercruise last year:
Fixed and sprayed:
And blended in:
934721_10151364319532541_1603297816_n.jp
Then, here is the final product with my headlights:
Also took the car for a drive for the first time since I started. Drives totally fine, can't tell that I've touched the cam timing. Of course I'm not boosting at all, so will need to wait until Tuesday to see how the car goes on the dyno. Only mayyyybe issue is that I drove 46 km's tonight and the car stayed very cool, never reaching normal operating temp. Water temps only just reached 70 degrees by the end of my trip and the oil temps never went over 60 degrees. They are normally both up around 80-85 within 10 minutes of driving. So I'm thinking perhaps my thermostat is stuck open. I'll check that out.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
