My quick net searching from other users experiences has not been good, some same they are great, but others that actually have proven and accurate ways to ascertain if the gauges are actually accurate have deemed them pathetic...
they are cheap, you get what you pay for, but they do have good customer service from what it seems and are prepared to give refunds if problems are found.
I personally dont like this, they are basically saying we sell good gear to those that dont know otherwise, but if you find are gauges are just cheap crap then we will give you a refund so we dont get majorly stung.
these seem like the gauges you have when you cant afford gauges.
ok to throw in your hyundai or lancer to look colourful and cool but if you actually need to use them for feedback info on whats going on wtih your engine then I wouldnt trust them...
I bought some Racetech stepper motor driven gauges of an Ebay Seller. They look ok and were only about $60 a gauge + postage. I was hamstrung though by the previous owner having cut holes in the dash on the passenger side with these gauges in them, but a few were broken so I got a new set, came with everything, sensors, wiring, mounting cup and visors. Not bad.
what guages are you after?
i'm selling a pair of blitz 60mm BLM carbon faced gauges in oil temp & oil pressure complete with sensors and wiring.
sexy ass gauges that light blue and looks bloody awesome.
if you're interested, send me a PM.
in syd as well so you can inspect and pick up.
Problem with ebay gauges as i see it...
One set might be fine. Another set might be out of whack - measurement wise.
So as long as you check them after installation (like boost, use a known working one from workshop) etc. Then OK to use. But just remember if they come up as not working so well, you might have done your cash.
I have 3 in my car that I put in for a bit of a lark. A semit serious lark, because I chose an exhaust temp, boost and oil temp.
First up, any black smoked lens is a shit idea. I might pull mine apart and see if I can't just put some clear glass in there. At night they're OK. In the daylight, with enough sunlight spilling into the car, they're quite hard to see. Especially if they're dusty.
Second up. They run really hot, and I suspect they draw a shitload of current even when the car is off.
Thirdly. My set seem to work quite well. The boost guage is certainly accurate. The exhaust temp gauge seems to read exactly where you'd expect the temp to be (I tapped a hole into the turbo's inlet for the thermocouple, so I'm reading manifold gas temp). The oil temp gauge also runs pretty much where you'd expect it to in the car, and I tested it in hot water with another thermometer before installing and it was accurate to within a degree.
Cheap, but cheerful. Not serious. BUt having peak recall and alarm functions makes them at least a little bit useful.
If you want a gauge that is affordable and accurate then go shadow. Their design is a knock off of defi.
I have a shadow pro black face gauge (opposite to above, visibility is great any time of day)
Accuracy is the the same as my boost controller.
I'm happy with mine. Even has peak recall, set boost spike alarm, dim the brightness, it should just give me a gobbie and then I've got everything haha
I use the Pro Sport exhaust temp gauge, its worked perfectly for 2 years since I bought it from another SAU member.
They have an annoying beep on startup that you can get rid of, other than that, go for it. Good value for money. :thumbsup:
A lot of pointless woffle in this thread
I got a prosport boost gauge.
Works fine in day and night.
Annoying thing is the beep on the intro start. You can turn it off but then you also lose the warning beep.
Also if you have multiple gauges the intro sync will be off but that will be the same for any gauge with no central controller (unlike defi)
  • 6 months later...
Bit of a thread revival
Any more info/experiences on the pro sport gauges?
I'm looking to buy a couple of temp and pressure gauges, if not prosport what other brands besides the ones mentioned above..
It may well turn out I buy some good jap ones but would like to know what other options are out there ATM
Yes I think I've seen them mate, are you talking about the replica ones?
I've pretty much decided to getthe Defi Din triple cluster like you have mentioned
Neat, reliable and will bolt straight In to factory dash
Inc 1 pressure and 2 temp gauges, so fuel pressure and water/oil temp is what I'll go with as the factory water temp gauge is shit (killed my first engine) and low fuel pressure ( killed my last engine)
I was going to go oil pressure as well but the factory gauge is reading close enough for my liking
Reliabilty was main main concern and I don't think you can go past the Defi's
http://www.skylinesaustralia.com/forums/topic/410614-apexi-el2-guages-boost-oil-temp-oil-pressure/page__p__6559210#entry6559210
These ones, If i went single like that id make sure they are 52mm so i can fit then into my own DIN cluster.
I always thought water temp was a bit of a gimic, Like the Exhaust temp guages? pretty sure the PFC and others read water temp.
Oil temp would be good, but the only reason i havent grabed a Unit yet is i cant decide what i want, When i get the car back im hoping the Profec B 2 Reads boost well enought to not need a stand alone boost guage.
How much is fuel pressure affected for street driving?
Well water and oil temp sorta move together so if your oil is hot youcan bet your water is..
I more or less want an accurate water gauge so I can keep on eye on the efficiency of my cooling pro radiator
In terms of fuel pressure, look at it this way...
If I know I had low fuel pressure die to the fuel pump only receiving 9 volts I would t have given it a bit into 2nd gear coming onto a high way and I definatly wouldn't have taken it to the drags at eastern creek
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
