Roy, UAS track days are for everyone. I have been accused of over favouring GTR's in the past, this was from a few of the zed guys. This was because we had 12 GTR's at the track one time and they get their own sessions along with race cars.
This day will sort out the men from the boys. I would not speak too soon as I have a good customer Gary who has owned a heap of GTR's, and is very experienced at the track. He has also done quite a few Targa's. He was the guy who drove the white N1 set up R33 GTR a few years back that ended up a tree, and him in hospital. The following year he wrote off another R32 GTR, head on into a tree. He is a good driver but has a big go. This year he is not doing Targa and put his effort into beat me at this track day. He has accumulated lots of good bits out of his 3 R32 GTR's and put them into one to make an awesome track car. Featuring Holinger sequential gear box which is good for at least a second a lap. He say more like 2. Big motor with 2540's and forged internals etc and 350kw at all 4. Stripped out with cage, big brakes etc. He is not beer talk. Will be very interesting. His fastest time was 106 .95 with the sequential box in the R33 N1 GTR. His new current race R32 GTR should do better than this. It will need to.
Tosh ( SW20 ) was over today and has has seen what we are doing. Last year the Zed was stadard internals and not too many mods but now it is full on now. We are running S15 turbos in the "Franken Zed "which are same HP rating as N1 spec so still can compare I guess, but yes lots of other things. It is again getting more like a GTR as now has Tomei RB26 solid lifters to add to the GTR bits in it.
I might Add Geoff from SSS Automotive will be out in his Gibson powered R32 GTR and has done more mods including better brakes and gear box, and will be in there. Joe also from SSS Automotive might be there with his well over 400kw at wheels R32 GTR. Power is not everything though.
  • Replies 106
Will surely be a great day John and a great opportunity to see some awesome machines in full flight.....
I'll be there sometime through the afternoon to come for some laps :P
p.s. As John mentioned I was out there yesterday and DAMN is he going to some major measures to lighten the car!
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
