S A U N S W - Texi, "the Original" @ Sutton Road
  • Replies 219
It has a muffler, measures around 103db at 1m 45degree angle at 5000ish....
Should be fine. When measured at 30m in the open I'd be VERY surprised if it fails.
Also, the measuring gear is at the front gate and we are at the back of the property (so 300-350m away).
That would be fine mate, 30 metres knocks off a lot of sound, you'd be surprised.
Side note: A friend of mine has asked if other cars are allowed to enter? He has a commodore.
Cheers.
Yes other cars are fine. Same rules apply etc
Loses 6db with every doubling of distance, so will be <75db at 30m
p.s. In!!
edit: have paid, will email entry form when I can print and scan it. Should make the .pdf forms into a form so we can fill them out with adobe reader ;)
How much access will spectators have? Will they be allowed to get to any corner to watch/take photos?
Not really mate, the facility is not designed for spectators and there are no walkways from the start point to any of the corners so anyone on course needs to be driven to their spot.
There's heaps of view from the little grandstand they have from the start to the first corner (first corner is so far away, without chicanes we can easily hit 250kmh it's that far.) You can also see a few corners towards the end of the course from the start line which sounds strange I know, but remember it's a loop. Ill get a pic and post up
That said, there is always marshals needed to sit in chairs out on the course (safe positions of course) and radio in if someone hits a cone on their way through. Those people usually bring cameras and get the best seats in the house so to speak and free food and drinks throughout the day from the club. So if she would like to do that for a while (doesnt have to be all day) then thats great for pics.
BTW Between runs everyone is lined up in a line similar to the line at TexiSOS days, and spectators etc can mingle and hang out with you while you wait for your next run as that area is safe. Hope that makes sense
Lol nah shitbox 31 will be rooted from 7000km of abuse by then :P
Will be in the micra.
Nah 31s are like cockroach's, it'll last forever!
Is the micra the turbo one for sale atm? I really want it, but the missus thinks I have toof many toys already
Good stuff Pete.
If you want to both enter and drive one car that's doable. Just write it down on the forms so we cant miss it.
Edit: Anyone can double enter a car, pretty simple, 2 drivers means two payments. You'll each get the same amount of runs as a normal entrant of course
yep thats it, not really for sale... Will have to sort some decent tyres and maybe put the LSD in before the texi :)
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
