S A U N S W - Texi, "the Original" @ Sutton Road
  • Replies 219
Dont know how you figured that out - BOV's are not cared about. Screamer and straight through exhausts are the big no no's
I figured venting to atmosphere included blow off valves that werent plumbed in but its a relief to hear i was wrong, in like flynn as soon as the money is in the bank, looks like we wont have the same problems with attendance the last track day had!
Small update, I have organised for this event to use a flying finish with lasers (similar to WSID) for timing. Each group has their run then those times will be uploaded to Natsoft throughout the day.
This does not increase the entry price.
cancel whatever other plans u have pezhead, event would be weird if your not there!
will have to wait till i get my rent from a flatmate till i can pay it, hope a fortnight from now still sees it with spots left..
update done.. to all those people 'thinking of entering' do it now or you may never get another chance.. If this doesnt fill it wont be coming back!
and before you ask if there are spots left we have 33..
its simon Cowell's dad. oh and lern to meme!
im 100% keen but dropping the gf's brand new ipad3 the other day means i cant afford it this pay ($330 to replace screen...figured just buy another one and use the smashed one myself) will keep me from paying for another 2 weeks. How are the numbers looking for this? oh and whats the history like with people going off and into the scrub? i have the ominous feeling the run off is less kind than wakefields?
Guest
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
