Just wondering if anyone knows anything about Jasma
Exhausts or where I might find some...
Everyone I've asked has no idea, and the websites
are all Japanese (which I'm no good at)
Thanks in advance
btw. the badge number on this particular exhaust is.
JASMA
051
96-000 509
https://www.sau.com.au/forums/topic/39526-info-on-jasma-exhausts/
JASMA = Japan Automotive Sports Muffler Association.
It's a standard that; if the muffler is constructed accordingly, they company making the muffler can weld on the JASMA badge. It's all about quality control, JASMA exhausts have to meet a 96db limit, amongst other things.
My Fujitsubo is Jasma rated at being quieter than stock - except between 4000 and 6000 RPM. Just where the EPA test it :P
The Fujitsubo site has good Jasma info - as well as dB ratings for all products - even sound samples!
Main site:
http://www.fujitsubo.co.jp
My exhaust:
http://www.fujitsubo.co.jp/search/prod-v.p...cnamID=00000514
Thanks Rezz... do u know whether its any good? or shud i sell it..
what do u suggest?
thnx again!
If it was my exhaust, I'd give it a good buffing and get it all shiny, and run it on the car for a while... I can't say that the Dual Dragger are THAT common, so in that case I'd hang on to it, unless of course you don't fancy the dual canisters...
JASMA approved exhausts run under 96dB for stocko cars right?
Have u had any or know of any experience with the dual drager?
I cant get any info on it, thus dont know whether or not its worth
it getting it fitted... Dual Canisters are fine, performance wise is more
important imo
The HKS Dual Dragger came about because of some ground clearance issues with the normal Super Dragger muffler on some cars, also at the time, the dual canisters were the "in" thing... most of the big-name manufacturers had their own "Dual type" mufflers. I wouldn't think performance would be any worse than a usual Super Dragger exhaust system, although it'd be a bit heavier.
If performance is the important thing, the only thing I'd do is sell the Dual Dragger and get a Titanium exhaust (any brand)... the weight saving alone is worth it IMO.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
