B-rice Posted June 19, 2014 Share Posted June 19, 2014 i bought redline and since i changed to it i find it hard to change from 1st to 2nd, 3rd to 4th is alright. I did change the clutch too so im not sure if i got a bad batch of oil or its the new clutch. With the old clutch and oil it was so smooth i could change with my palm on the stick. Any ideas would be great Link to comment https://www.sau.com.au/forums/topic/395434-rb25det-gear-box-oil/page/2/#findComment-7316309 Share on other sites More sharing options...
KiwiRS4T Posted June 19, 2014 Share Posted June 19, 2014 i bought redline and since i changed to it i find it hard to change from 1st to 2nd, 3rd to 4th is alright. I did change the clutch too so im not sure if i got a bad batch of oil or its the new clutch. With the old clutch and oil it was so smooth i could change with my palm on the stick. Any ideas would be greatIf your box was ok before you should have held out for the Motul. Does your clutch pedal have the same amount of free play as previously? Link to comment https://www.sau.com.au/forums/topic/395434-rb25det-gear-box-oil/page/2/#findComment-7316611 Share on other sites More sharing options...
B-rice Posted June 19, 2014 Share Posted June 19, 2014 No the freeplay has gone. Lift slightly and it engages straight away. Link to comment https://www.sau.com.au/forums/topic/395434-rb25det-gear-box-oil/page/2/#findComment-7316729 Share on other sites More sharing options...
KiwiRS4T Posted June 20, 2014 Share Posted June 20, 2014 No the freeplay has gone. Lift slightly and it engages straight away.That'll be your problem... not the oil. Link to comment https://www.sau.com.au/forums/topic/395434-rb25det-gear-box-oil/page/2/#findComment-7316796 Share on other sites More sharing options...
B-rice Posted June 20, 2014 Share Posted June 20, 2014 So clutch needs to be bled.? Had been told didn't have to so I never did it could have done it whilst I was still under the car. Link to comment https://www.sau.com.au/forums/topic/395434-rb25det-gear-box-oil/page/2/#findComment-7316800 Share on other sites More sharing options...
iruvyouskyrine Posted June 20, 2014 Share Posted June 20, 2014 I would definitely be re-bleeding the clutch for sure. Pain in the ass but a requirement in my eyes. Link to comment https://www.sau.com.au/forums/topic/395434-rb25det-gear-box-oil/page/2/#findComment-7317551 Share on other sites More sharing options...
mistermeena Posted June 28, 2014 Share Posted June 28, 2014 (edited) I have a slight notch going 1st-2nd (only when cold) and I think the redline lightweight shockproof has actually made it worse lol. I was going to try the yellow redline next time but would I be better off just using the nulon g70 addative instead? Edited June 28, 2014 by mistermeena Link to comment https://www.sau.com.au/forums/topic/395434-rb25det-gear-box-oil/page/2/#findComment-7324329 Share on other sites More sharing options...
