Aero front bar, some simple skirts on the side and rear would top it off. Looks good though, In a whale like way lol
The way you damage front bars; an Aero front bar is just going to end in tears.
Dale speaks wise. Well the car is going to be lifted in time to gain benefits from the engine upgrade and forced induction. So a aero bar may come later but right now its all muffler on deck
We aren't talking about me here, but about this beached az whale bro.
I don't know for some reason I liked it better with a black front bar.
But what do I know, I drive an emo
  • 3 weeks later...
Ok so havent updated in a while and some changes are happening to the stagline: First is a "new" VLSD out of a wrecked jap spec 350Z coupe $490 posted from japanese import spares to my door in newcastle, is going to be shimmed and replacing the 3.3 standard open diffs that sedans are graced with. Should be interesting to see how it goes. Has anyone here ever done it?
Also have a major exhaust leak at the moment. Hole roughly an inch wide and 5inches long. Solution is a midpipe from a V35 coupe. Same length but with a smaller muffler. Cant use 350Z as it is 6inches shorter. This with the straight pipes out the back will result in a nicer and deeper note (hopefully).
Also doing a general oil and filter change and transmission fluid change. Just a few things to get after that: M35 front reo bar, passenger weathershield, inner gaurds and under plastic and thats basically how its staying until july when it gets a new engine, box and other things too........
Edited by Howaitonaito
you drive an emo......... hope her daddy approves :mrt:
Edited by joshm35
  • 3 weeks later...
Had the car raised to goto panel beaters because some L plater hit it, not bad damage tho. So its 100mm ground clearance on R32 GTST stock wheels that just clear the brakes. Got the diff and coupe midpipe but its on hold until car gets fixed, then theyll be put in and it will be getting slammed yet again. Seat rails is what i wanna fix because tho the car is (was) slammed it still felt high and would love some super low rails, anywhere i can get some. Would like to keep factpry seats but not required.
Yeh bride super lows, but they won't fit the stock seat, you'll need something like euro 2's for comfort..
Speak to ARK design. They have good seats for cheap too with bride rails
And then compare pricing from this Ebayer http://stores.ebay.com.au/4x4-and-Performance-Online?_trksid=p4340.l2563
He's a Stagea owner & member on SAU.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
