Aero front bar, some simple skirts on the side and rear would top it off. Looks good though, In a whale like way lol
The way you damage front bars; an Aero front bar is just going to end in tears.
Dale speaks wise. Well the car is going to be lifted in time to gain benefits from the engine upgrade and forced induction. So a aero bar may come later but right now its all muffler on deck
We aren't talking about me here, but about this beached az whale bro.
I don't know for some reason I liked it better with a black front bar.
But what do I know, I drive an emo
  • 3 weeks later...
Ok so havent updated in a while and some changes are happening to the stagline: First is a "new" VLSD out of a wrecked jap spec 350Z coupe $490 posted from japanese import spares to my door in newcastle, is going to be shimmed and replacing the 3.3 standard open diffs that sedans are graced with. Should be interesting to see how it goes. Has anyone here ever done it?
Also have a major exhaust leak at the moment. Hole roughly an inch wide and 5inches long. Solution is a midpipe from a V35 coupe. Same length but with a smaller muffler. Cant use 350Z as it is 6inches shorter. This with the straight pipes out the back will result in a nicer and deeper note (hopefully).
Also doing a general oil and filter change and transmission fluid change. Just a few things to get after that: M35 front reo bar, passenger weathershield, inner gaurds and under plastic and thats basically how its staying until july when it gets a new engine, box and other things too........
Edited by Howaitonaito
you drive an emo......... hope her daddy approves :mrt:
Edited by joshm35
  • 3 weeks later...
Had the car raised to goto panel beaters because some L plater hit it, not bad damage tho. So its 100mm ground clearance on R32 GTST stock wheels that just clear the brakes. Got the diff and coupe midpipe but its on hold until car gets fixed, then theyll be put in and it will be getting slammed yet again. Seat rails is what i wanna fix because tho the car is (was) slammed it still felt high and would love some super low rails, anywhere i can get some. Would like to keep factpry seats but not required.
Yeh bride super lows, but they won't fit the stock seat, you'll need something like euro 2's for comfort..
Speak to ARK design. They have good seats for cheap too with bride rails
And then compare pricing from this Ebayer http://stores.ebay.com.au/4x4-and-Performance-Online?_trksid=p4340.l2563
He's a Stagea owner & member on SAU.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
