Aero front bar, some simple skirts on the side and rear would top it off. Looks good though, In a whale like way lol
The way you damage front bars; an Aero front bar is just going to end in tears.
Dale speaks wise. Well the car is going to be lifted in time to gain benefits from the engine upgrade and forced induction. So a aero bar may come later but right now its all muffler on deck
We aren't talking about me here, but about this beached az whale bro.
I don't know for some reason I liked it better with a black front bar.
But what do I know, I drive an emo
  • 3 weeks later...
Ok so havent updated in a while and some changes are happening to the stagline: First is a "new" VLSD out of a wrecked jap spec 350Z coupe $490 posted from japanese import spares to my door in newcastle, is going to be shimmed and replacing the 3.3 standard open diffs that sedans are graced with. Should be interesting to see how it goes. Has anyone here ever done it?
Also have a major exhaust leak at the moment. Hole roughly an inch wide and 5inches long. Solution is a midpipe from a V35 coupe. Same length but with a smaller muffler. Cant use 350Z as it is 6inches shorter. This with the straight pipes out the back will result in a nicer and deeper note (hopefully).
Also doing a general oil and filter change and transmission fluid change. Just a few things to get after that: M35 front reo bar, passenger weathershield, inner gaurds and under plastic and thats basically how its staying until july when it gets a new engine, box and other things too........
Edited by Howaitonaito
you drive an emo......... hope her daddy approves :mrt:
Edited by joshm35
  • 3 weeks later...
Had the car raised to goto panel beaters because some L plater hit it, not bad damage tho. So its 100mm ground clearance on R32 GTST stock wheels that just clear the brakes. Got the diff and coupe midpipe but its on hold until car gets fixed, then theyll be put in and it will be getting slammed yet again. Seat rails is what i wanna fix because tho the car is (was) slammed it still felt high and would love some super low rails, anywhere i can get some. Would like to keep factpry seats but not required.
Yeh bride super lows, but they won't fit the stock seat, you'll need something like euro 2's for comfort..
Speak to ARK design. They have good seats for cheap too with bride rails
And then compare pricing from this Ebayer http://stores.ebay.com.au/4x4-and-Performance-Online?_trksid=p4340.l2563
He's a Stagea owner & member on SAU.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
