Should we get admin to move you back to your v series buddies, so you can talk about changing timing belts, what wheels fit, broken cd changers, what plenum spacer to run, and what does this button under the dash do, or would you like to stay in here with the big boys...?
But, but, I need to know how to wire up my neons for mad street cred.
Also, what colour should I plastidip my wheels to attract wimmenz?
Fish gotta swim, birds gotta fly.....Alex gotta lighten up.
Jjjeeeeeezuz its only a joke alex.
Plus i dont have a button under my dash.
You have the VQ35DE you should be spacing your plenum more than me.
I have double din standard so my CD player has never broken.
I also know what wheels fit on my car, thank you.
the wimmenz simply do not get attracted to V35s. Ill admit that.
Hahahahahahhah
First time back in the Stagea section for a long time, only to see Craig hasn't changed lol
Why don't you stop Trolling and f#$k off back to the Flat capper section. Oh sorry you in Marks thread........you'll fit here!
:P
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
