Should we get admin to move you back to your v series buddies, so you can talk about changing timing belts, what wheels fit, broken cd changers, what plenum spacer to run, and what does this button under the dash do, or would you like to stay in here with the big boys...?
But, but, I need to know how to wire up my neons for mad street cred.
Also, what colour should I plastidip my wheels to attract wimmenz?
Fish gotta swim, birds gotta fly.....Alex gotta lighten up.
Jjjeeeeeezuz its only a joke alex.
Plus i dont have a button under my dash.
You have the VQ35DE you should be spacing your plenum more than me.
I have double din standard so my CD player has never broken.
I also know what wheels fit on my car, thank you.
the wimmenz simply do not get attracted to V35s. Ill admit that.
Hahahahahahhah
First time back in the Stagea section for a long time, only to see Craig hasn't changed lol
Why don't you stop Trolling and f#$k off back to the Flat capper section. Oh sorry you in Marks thread........you'll fit here!
:P
