Hey josh...give him a break. We were all flatcappers or hard Parkers once upon a time. While marks a little bit of a smart arse at times I pretty sure most of its in misunderstood humour.
P.s plus I don't know whether his my kid yet...i had sexy time with this chick(I think....she was a little hairy) years ago and he does sort of look like a like me! A chick magnet! :P
furry muff
  • 1 month later...
Hey kids its been a while since ive updated this.
First of all i had a great time at the cruise. Craig and Theo did an awesome job. Hopefully i'll be able to keep up on the next one
Second of all i have sold all but one of the remaining V35 sedan parts with the bonnet left. All the funds will be going to "markneedsanemanage foundation" (feel free to donate) will busk if have to.
Thirdly the cam timing sensor can go EADC!
#NoFace
Edited by Howaitonaito
I'll do what I want with my farkin' lemons, you bloody young smartarse!
And it ain't calm, that's for sure!
Your memes are amazing, but it does make me wonder how you find time for anything else in life while searching for awesome memes
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
