As 1st November 2013 all parts needed for the swap have been bought and are in a box ready.
-Turbo.
-Scottys Dump.....pipe.
-Emanage with laptop
-blitz filter
-NGK LFR7AIX x6
So all i need to do is save the money for scottys fees/travel/tune/accom.
Anyone on here have the MOMO option woodgrain steering wheel?
-Turbo.
-blitz filter
-NGK LFR7AIX x6
I have a momo woodgrain steering wheel. But your not having it!
As far as accom goes if you had a wagon that would be sorted. See not just for back packer bodies ;)
I dont want it. Mine was missing the plastic torx bolt covers on each side and the cover on the bottom of the airbag. Can you see if they have a part number on them at all?
Compression rod bushes attempt #2. Update: so far so good. Big thanks to craig for putting them in like a boss.
Went for a ride in craigs car today...hhhmmm dont think i have ever grabbed the door pull that hard of any car in my life. After being in that i now realise that my car in its current form needs ALOT of work and is a POS!
Also: im sorry for not listening to craig, scotty and dale and not buying superpro in the first place and buying some shite ones from 'murica. i have learnt my mistake.
Im sowwy....
Edited by Howaitonaito
  • Like 1
  • 4 weeks later...
So the bushes are sweet as. Engine light on again. Going to have it read again tomorrow (or try to) and see whats the problem is.
Other than that nothing has changed and still saving for this swap.
Just thought id share a pic a mate took.
#NF
20b twin turbo stagea nose skyline sedan. Theo i have the best of both worlds!
Got it cheap from a JC cosmo.
INB4 shitstorm!
  • Like 1
Going to start planning dates for this swap and hopefully get some solid dates down by the end of the week.
I know very few people read this or keep up with it. But for those who do it happening in hopefully Q1 2014. May or may not post pics.
  • Like 1
Dammit... yo ganna beat me!
why would you keep the stock twin turbo's on a 20B ???Big f**k off single hangin out tha bonnet FTW
So he can says "I haz twin turbz".
Also FYP.
Keep posting mate. I prefer wagons but I'm impressed with what you have done so far and keen to see it all done.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
