Hi guys
i just put a Neo in My R33 GTST S1
my mate think the r33 S1 ecu will not work
need info on how to wire R34 coilpacks to R33 S1 loom
and looking for anyone on what i should do or look out for
and what ways should i go with loom and ecu
i got told you can bolt all r33 stuff to the Neo motor and use r33 loom
any info will be good thanks
TAHNKS
https://www.sau.com.au/forums/topic/395631-puttng-neo-in-my-r33-s1/
Dude do yourself a favor and buy a R34 RB25det neo ECU+loom.
Why root around buying series 1 and 2 RB25det parts for your NEO engine? Neo loom and ecu is a direct plug and play with minor modification.
Dude do yourself a favor and buy a R34 RB25det neo ECU+loom.<br><br>Why root around buying series 1 and 2 RB25det parts for your NEO engine? Neo loom and ecu is a direct plug and play with minor modification.<br>
its a direct plug and play into the engine yes but not the car, you would have to wire the neo loom to the car, not difficult if you know what your doing.
but you have a point.. it will give a better result. you can then use the nistune on the 34 ecu also
R34 loom as to be wired in to your dash loom
so many people have done NEO swaps and still use there own Loom
need more info guys...will R33 S1 power NEO motor ? and will RB20 nisstune power a NEO ? and putting in R34 loom and ECU in R33 S1 gtst what will be need to be done to make all of it work ? need as much info guys plz thanks
S1 loom uses a separate ignitor this wont work with the neo coils and you wont be able to fit s1 coilpacks in there. So the EASIEST way to make it all work would be to run a Series 2 RB25 loom, it will plug into your 33 no worries, gets rid of the ignitor and then you can run neo coil packs. The RB20 ecu will run it no worries.
Adapting the neo loom and running the neo ecu with a nistune would give a better overall result but at the expense of more work since theres a fair bit of rewiring to make the neo loom fit your r33.
yes you can still use all those things HOWEVER making the abs work will be very time consuming.
just get a s2 R33 loom
i have the s2 coilpack plug to go to the ecu loom so cant i use the r33 s1 loom and wire that s2 plug on there ?
  • 11 years later...
He was last active nearly 10 years ago. Thread necro no likely worky worky.
The best advice is clear out all the old crap, use an aftermarket ECU, build a complete new loom from scratch.
The next best advice is use an R34 engine loom & ECU, adapt it where necessary to mate to the R33 body loom. Then at least you have a Nistunable ECU.
The worst idea is to keep any of the R33 stuff.
  • Haha 1
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
