Cals Budget 32 Build
So had a quiet day at work today and luckily the boss went home early morning. So i ended up finishing spraying the cage in the 'Plumb Purple' looks pretty schmick. I also touched up the floor with some matte black including the harnes eyelets. Then bolted the GTR seats into place. Then ran the harness as required on both sides. Adjusted mine up took a few goes and just need the mrs to sit on her side to adjust hers. They feel good and weird at the same time as ive never had proper racing harnesses in a car ive driven before. Also got the bonnet pins mounted and secured properly in the radiator support. Just need some rubber spaces to remove the free play in the pin itself. So heres a few picks. Now just saving for front rear screens and sunroof insert. Then shes ready for racing :)
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
So finaly a small update. Wired up the AFR meter to the new 02 sensor. And found a small cheap china spec POD filter that fits where i need it to. With the headlight removed and carbon funnel put there will be good enough. Picking up a full cat back exhaust friday to make it legal for texi days. And saving for windows which should be next month or so.
As promised here are some pics from my GO PRO, full 2min car tour video is uploading to YOU TUBE as we speak. will add link when finnished.
And couldnt leave the daily out :P
So received a nice box in the mail yesterday. A 12" thermo fan. Having already wired in a relay and switch ages ago it was a simple task of mounting it to the radiator and connecting 2 wires. Presto the fan is alive. Seems to move a solid amount of air which should be more then enough for those track days ;)
Also got a nice used 3" exhaust brought to my house for a cheap price. Its cat back full system, beat up but will do the job perfectly. Dont have picks of it yet as it needs to be modified so i will be able to un bolt the side pipe where the cat would normally sit and attach the full system to make it a nice 2 bolt on off 5 min job. My original exhaust hangers are all still in tact along with all the D rubbers :)
Update to come shortly with picks of exhaust before and after :)
Big red is main ISO switch, from left to right, Fuel Pump, Alternator Power, Thermo Fan. As the original wiring of the car was altered when i brought it to run the battery in the boot for some reason the signal wire for the alternator wasnt working so i just wired in a new one with a switch. The custom fuse box runs all the switch power, gauges, thermo power ect, along with running the standard 32 fuse boxes. Rear of car is custom wired by me as I had no normal rear harness.
  • 3 weeks later...
So update-
Exhaust has been modified now so a full system can run with a muffler and a cannon out the back 3 1/2 inch. Now all thats required is to unbolt the 3 bolt flange and swap the full system for the side pipe. Now she just needs window glass and i can take her out on track. Not bad going from a rolling shell to full car in under 12 months.
If you want to be able to swap your exhaust out really quickly, use what is called a tri clover. Basically like a v band clamp, but it does up with a wing nut, so you dont even need a spanner or ratchet.
Have one on my R32 GTR so for track days i can swap it out in under 5mins at the track if need be for some straight through goodness.
MMMMM straight through goodness lol. Ill keep it in mind ;)
So big update, well not really just picks. Plumbed up the catch can properly, ordered the windows off FATZ so they will be coming and be installed on monday :) She will look like a new car with glass in the rear and a non smashed front screen. Decided will attempt to plexi the quarters and sunroof. Cant wait to see what it looks like. Then shes ready to go! Also installed second hand dash cluster. Purely for the RPM. The dash lights work. Tacho works. Speedo needs the drive in the RB25 box modified. Fuel gauge, oil pressure and boost not working as the rear harness is only a 7 core trailer wire i did myself and using aftermarket oil pressure gauge. But makes the interior look complete. Needs door trims as well.
Here's some recent picks of exhaust and engine. Please not the catch can lines have now been secured with a single U clamp to the RH T belt bolt area. So holds them down off the bonnet :)
1013382_10152973788185521_995750091_n_zp
Ah just the stocker. I couldnt rape his old beast to much lol. Ive already grabbed the harnesses and now the rear window lol. Pretty sure im gonna have to give him a free sponsor spot on my car cause half the stuff in it is from him :P
Yah the entire front end is pretty much from fatz. Intercooler, Front bar, Lights, blinkers, radiator, front glass, rear glass, bar support front, carbon style grille, both harnesses. So yah lol a fair bit of money has gone his way ;)
 Share
    • I have driven it slowly around the block, didn't notice any issue with the brakes. It is a vacuum brake booster.
    • Hi all, so some of my speakers still work some I don’t think work. The old head unit is still all functional. If I keep the stock head unit as I feel it’s vintage then can I just pop in new speakers - would that be plug and play? Would I need to bypass the amps in the doors and back? Heard there’s 3 of them.  anyone run a blue tooth into the stock head unit? Or is the only option running one of those tape decks with cable coming out?  my cd deck controller although rare I don’t think is working anymore either. Guess if I got that working with the speakers then I could load some cds.    just seeing my options here if anyone has some advise.
    • My trusted mechanic is Tunehouse in Calder St, Marrickville. He's the guy who did the ECUtek dyno tune on mine. I'm nearing the 85k mark for my motor and I'm considering getting the oil galley gaskets done as preventative maintenance when the time comes. Since my garage isn't big enough for such a task, I'm definitely going to be handing it over to him. You'll be impressed by how clean he keeps his workshop. It gives you the confidence he and his employees will look after your vehicle with the same pride.
    • The Bogan Sports Car now has fresh gear bag and diff oil The old gear bag oil was nice and clean looking, the old diff oil was average looking, not horrible, just dark, I've seen worse in other cars, much worse Good things was that both drain plug magnets looked good with zero bits of anything apart from a small coating of that typical black goo you get on the diff plug, it was probably the original diff oil, but nothing shiny The shifts are sweet, and the Torsen is Torsening like a boss (tested in the work vehicle maintenance yard after work). LOL In other noise related news, the Racing Beat axle back sound nicer than stock from outside with the roof down, but still pretty quiet, but it's not noticeable at all really inside with the roof up.....maybe it needs a header.....🤪  This is what a OEM header looks like 😝 > 🤣🤣🤣🤑
    • what about people that have loud exhausts on automatics?
