Hey guys
anyone here do any proffesional mobile installations or know someone that is high class with their work that can supply and install an alarm , and also someone who does window tinting .
sydney located
cheers guys
Edited by sky017
https://www.sau.com.au/forums/topic/395821-car-alarm-installer-window-tinter/
A few friends have gone with Martin at Ground Zero Tinting. Heard nothing but good things about him. I think his contact number is: 0424725250. I know that his prices are very competitive but not too sure if he is mobile.
Perfect job with lifetime warranty.
Hang on a sec...
Now I've always wondered about this lifetime warranty thing!
Does it apply to the car, the tint or me?
If I decide to sue the tinting company, is my life then in danger?
I recommend Daniel you see, and then it's not in his interests to knock me off ;)
I wouldnt mess with them mate, take a look at the butterflies on their warranty page - they just look angry.
http://www.solartint.net.au/lifetime-warranty/
Last time I spoke with Daniel, he was still awaiting the machine arrival from the states. They are getting a laser cut machine or something with all the window templates for cars pre loaded - to make sure its a 100% accurate and clean finish.
When it arrives, i'll be going to Carbon Car Systems for tinting too for sure.
