Yeah as above, make sure its on the return line. Shouldnt have any issues with flow really, there shouldnt be much pressure drop through the cooler and the pump should be able to push the oil through a cooler. Remember it does push the oil back uphill when it returns to the reservoir anyway
Random plug is the power steering pressure switch. Basically tells your ECU that the power steering is active and the ECU compensates to keep the revs steady
I don't really see that being a problem (besides maybe the cooler not being in the 'coolest' place), you shouldnt have any issues with feeding oil back. The cooler (once full) is not alot different to it just being a hose. There is probably a slight amount more restriction, but seems weird that you are having issues with this setup
Weird eh? Mine runs exactly the same and it runs perfectly.
I didn't even bleed it, just started the car and turned the wheel back and forth at the same time topping up thr reservoir. Happy days, perhaps see if there's a blockage somewhere.
I've done the same setup on another car years ago, no dramas there too (although was a poster street car that never saw the track).
  • 1 month later...
Matthew, I got quoted around $100 for the single power steering pipe, however I wasn't sure that was the only thing leaking.
I ended getting the entire power steering piping swapped from another R34, cost about $400 with labour.
No more leaks.
  • 10 years later...
10 minutes ago, GTSBoy said:
Ever seen a sock on a PS reservoir in a Jap video and wondered why?
Not until I googled it, now I remember lol. Seems like it's just to clean it up. But it doesn't stop the leak, I have a leak issue though? Thinking whether I need a new bottle, surely not lol.
Fluid gets hot, expands, comes out the cap. The seal might be old, dry and cracked....but realistically, this is something that has been happening since long before the seals should be able to be considered to be old and dry and cracked.
A better PS fluid cooler is a helpful thing. I plumbed the trans cooler from an R34 into mine. Deleted the near useless loop of hardline in front of the radiator that Nissan thought would do the job.
If there's no rubber gasket you need a new cap. There should be a rubber gasket, depending on the car. If you are driving the car hard and the power steering is getting hot it will spit out of the reservoir. I have seen people tap the cap for a hose + overflow catch bottle placed somewhere that it will fit.
There is no seal, that's the thing.
I'm not sure if skyline's have it, I haven't been able to find info on it.
3 minutes ago, GTSBoy said:
Hence why I didn't dwell on the seal aspect of the discussion and talked about why it overflows and what can be done to help.
Ah right, I wasn't going to mess around and install extra crap. Surely it should work right out of the factory lol
Edited by silviaz
What specific car is this? I know for sure my R33 has a rubber sealing gasket on the cap. Not unusual to get a bit of seepage from it either.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
