Anything is possible but it's highly unlikely..
Your pump should turn off before that happens and fuel will not pass through the reg the wrong way anyway..
You have another issue, you need to find it
Pull your I injector rail out, turn ignition to on and see if fuel comes out of the injectors..cause it shouldn't.
If it does I'm confused why it is doin it..would seem something is wired up wrong or could be as simple as a setting in your ecu..
Reading your other thread that states you have a 26 pfc and a 25 loom (or whatever the f**k you have done) it seems obvious you have muffed something up and your injectors are getting voltage full time..
disconnect fuel pump and test injectors with a multimeter or even just a test light.
Then when you realize this is the problem figure out why....
That should be fun. :devil:
I have a 26 loom and a guy on here used the original 25 loom to make it compaitble with the other stuff, installed injector dropping resistor an all that. anyway have come to the conclusion this is not common and somthing is way effed up and I shall pay a professional to fix my problems :rofl:
Injectors have constant ignition power or 12v at injector with ingition turned on & They earth through ECU.
So put test light on positive battery terminal and check for earth at injector plug, If earthed you have problem!
After Fixing problem, Drain the oil, crank out cylinders, refill with clean oil, add 20-50ml oil to each cylinder, crank over till oil pressure then start.
At least it'll flush the sh#t out after rebuild!
Edited by 32TAXI
Or a stuffed reg can do this, pull vacuum hose off the reg and see if fuel comes out.
Could make sense, if its running out of a busted reg, it'll run into the plenum, and therefor into the cylinders...
The injectors were plugged in with cas disconnected i assume they are stuck open or receiving voltage
sounds like a wiring issue as the injectors wont leak unless they are opened via ecu. what ecu?
Status tuning ever heard of pfc doing this? i have an old R32 Gtr mines computer at home (no idea whats on it) so im gonna plug that in and see if it happens again and that will diagnose what is the problem immediately
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
