doh, i just bought 8000k for mine- very blue
Is that illegal or something?
Not overly fussed about visibility as its a city car in perth. It doesnt rain much n u could also drive with your headlights off half the time n not notice with the street lighting...
Thanks guys
I've done a bit of research into the topic. 4300k is the closest to daylight colour and after that they start going blue. Most OEM's use 4300k globes but the most popular aftermarket colour is 6000k.
The most contributing factor is the type of headlamp they go into. Cut glass lenses (the old school type) tend to throw the light around. This is because hid light output is very directional and refracts easily. The best lamps are the projector and free form designs. They control the light much better and give a defined cutoff. Important so your not blinding oncoming cars.
Cheers
4300K is light yellowish, 5000k close to white (will look slightly off if you have white LED parkers), 6000k is white, will match white LED parkers the best and probably the highest you'd want to go for looks vs. visability. Anything higher tends to blue/purple and will be worser off for visibility.
I have 6000k in my HR31 and now R32 and are absolutely awesome :). Just make sure they are not aimed too high and blind other road users. Also if you are going to use them in non-projector type headlights you should probably get a Hi/Lo type kit as you will blind people no matter where you aim them ;)
Edit: Added a pic of my conversion half done.
Edited by ColdFusion
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
