  • Replies 66
Posted Images
ok, so i plugged the nistuned z32 ecu back in and recorded the dash with aircon on and aircon off. I also recorded the standard ecu with aircon on and aircon off.
This is with the standard ecu plugged in
This is with the z32 ecu plugged in (note the exhaust temp lamp)
The idle with the z32 ecu in is higher and it was recorded second after i had already had the car idling for a minute or 2 on the standard ecu. With the air con on with the z32, the car doesnt sound like it does with the standard ecu.
I took the car for a spin with the z32 ecu plugged in and revved it out to about 5500rpm in second and third and it didnt stutter or go into limp mode at all. My consult display also shows no fault codes with the z32 ecu plugged in.
We put the Series 2 33 changes in based on information from another customer when they installed in their vehicle. The main problem is I dont have a S2 wiring diagram/pinout to compare against. Yeah I was thinking series 1.5 also
Anyway been going through their emails back from Aug 2010 and found this page (attached)
So pin 32 is the Exhaust Over Temp lamp on the S2 RB25. It connects to the Check Engine Light output on the Z32 ECU. So effectively your exhaust temp light is the check engine light output from the Z32 ECU now
Question now is what is the Check Engine Light output on the S2 RB25 pinout? I'll contact the customer who bought the NZ workshop manual and find out
Edited by darkhalf
In the video with the z32 plugged in and the a/c on the idle doesnt seem to go up a bit like the name fast idle control device dictates it should. Then, when its turned off it jumps up abit then settles again, so i dont know if the FICD is actually working or not.
On the pinout diagram for the z32 I cant even see exhaust temp lamp so I guess it doesnt use one and which ever pin is the r33 series 2 exhaust temp lamp on my loom is plugged in to something it perhaps shouldnt be on the z32 ecu and its turning the lamp on.
EDIT: Just read Matt from nistunes post above. Let me know when you hear back from them Matt.
Edited by Mitcho_7
I've got those diagrams above (link on second one broken)
www.gweeds.net/nismodore/rb25diagram.jpg
The ECU pinout from the same site has the Series 1 mappings for both lights
Series 1 uses
Pin 32 = Check engine light
Pin 33 = Exhaust temp light
which ever pin is the r33 series 2 exhaust temp lamp on my loom is plugged into something it shouldnt be on the z32 ecu and its turning the lamp on
Series 2 uses
Pin 32 = Exhaust temp light
Pin ?? = check engine light
Z32 ECU has no exhaust temp light output. Its Pin 32 output is 'check engine light' as previously posted
Series 1 uses
Series 2 uses
So essentially the exhaust temp light with the z32 ecu installed how it is at the moment is actually the check engine light?
If that is the case and the check engine light is now through the cat light disconnect the tps and check it to see if it's using the standard 1.
And if it was using the cat light why is it throwing the light with no codes, I reckon pull the plug for the cat sensor first and see where you stand.
Edited by Stevoss
I have no idea how to do this and dont really want to be pulling out wires etc as the car is also my daily and I will need it next week
You raise a good point about why the lights on with no codes, im only going off of what my ecu consult display from ecutalk.com says when I go into faults.
The good news is its easy and very quick to connect and disconnect the tps, you just look at the top of the motor and where the throttle butterfly is that moves when you push the accelerator peddle it has a small black box on the other side, you push in the little tab on the plug and pull the back half to release, it will log this as the fault code and display the dash light, you can clear that with consult after.
You are brave man ..! Or was the ECU tuned?
Also more on the topic, what is the colour of your Crank Angle Sensor?
(black housing, or metal?)
Edited by Torques
dont know what you mean? the only way i know of it working is the z32 ecu with the nistune daughter board running the standard ecr33 rb25det tune.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
