  • Replies 44
Actually, the management has changed. The volunteer track staff and ANDRA officials may still be there (as they do it for the love).
BTW, the NSW State Government owns Sydney Dragway and leases it to the company which runs it.
I always thought there was no point using "Western Sydney" as there is only one strip in Sydney.
That r32 ute did a best time of 14 sec (what I saw)
I myself, started off with doing 2 flat 13 sec passes
Then finally got my launch better and pulled off 2 x 12.5 sec and 1 x 12.3 sec pass. 60' time still needs some tinkering, but you can definately feel when you get that launch right, the g forces, OMG. haha. Best 60' was 1.7s
There was also a a guy in a 33 GTR silver, looked like 17" te37's, saw him run a 13sec
And another guy in a maroon 32GTR ran a best of 12.2. He expressed to me that he had 370kw.
Was a bit muggy and intake temps were at 52/55 degrees all night. A cooler night will definitely/hopefully get me in the high 11's
Yeah 12.2 was my first and best run of the night trying my launch technique coasting after 3rd gear. 1.7 60 footers was the best i could do. Need to play with tire pressures next and try and get down to 1.6. Eat_me nice car mate sorry I was a bit out of it had a really bad case of food poisoning and just wasn't feeling up to it.
nice work ;)
last time i did a good launch, i ran a pb of 12.9 and got towed back to the paddock ;) that was dutton 07, never been back since, but on my 3rd gearbox since then LOL
damn i need 4wd launches LOL
Anyone see the Silver Evo 2???
Was it's 1st time to the track and on a standard box..
Ran a [email protected]
That's good for a ten second pass... was just babying it off the line.
Still has more boost to put into it... Will be very interesting to see what it runs once fully complete
All good man. For all I know, you were in the zone haha
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
