  • Replies 191
Hi how much for 6x id1300 injectors if U have them
Hi mate,
We don't do ID's we stock the BOSCH injectors which ID then match flow.
Cheers,
Brendan
(VM)
Then why are u advertising id for ?
Many sellers do it.
Riding the coat tail of injector dynamics I suppose .
Edited by Ben C34
  • 1 month later...
Massive clearance on Siemens/VDO metal body injectors - 380cc @ $95/each.
These are getting very rare and no longer manufactured.
  • 1 month later...
G'day mate,
Can I get a price on a set of 6x 1000cc TOP feed High Impedance injectors to suit 11mm Greddy fuel rail on a ECR33 RB25det... inc delivery to Perth.
Cheers.
Edited by Nemesis
G'day mate,
Cheers.
Hi,
Sure thing mate, BOSCH 1000cc injectors (E85) unit's, 11mm o-ring extensions and plugs would be $660 incl. delivery to Perth for the complete set-up.
Let me know,
Brendan
(VM)
  • 3 weeks later...
New 1150cc @ 4 BAR BOSCH injector's in stock now (unmodified)
> E85 compatible
> Improved Spray Pattern
  • 3 months later...
  • 1 month later...
  • 3 weeks later...
Hi mate!
I would go with the BOSCH 1000cc injectors, they are the only unit's which are purpose built for E85 and race fuels.
Price on a full set of 6x flow matched with extensions and plugs would be $660.
Cheers,
Brendan
(VM)
So these 1000cc EV14s are different from the other larger size injectors you offer?
How large do the bosch EV14s go?
Hi,
Sure, the 1000cc injectors are purpose built for use with all fuels including E85.
They are a 3/4 length injector however extensions can be supplied for them as well to make them full length.
Cheers,
Brendan
(VM)
Hi,
Cheers,
Brendan
(VM)
Yea these are the ones that I already have. I am wondering if you have the higher CC EV14s or are these the largest you have of these type of injector?
What are the larger options for R34 GTT?
Can I have a price please on a set of short (40mm) 1000cc top feeds and a rail to suit that will fit under a standard RB25 intake
Cheers
Andrew
Cheers
Andrew
Hi mate,
The only 1000cc inceptors we have are 3/4 length which are a slight longer unit.
Will this be suitable?
Cheers,
Brendan
(VM)
I'll have to do some measurements. but from memory they will foul.
Let me know though.
Do you have a part number for the specific ones you require?
  • 1 month later...
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
