  • Replies 191
Hi how much for 6x id1300 injectors if U have them
Hi mate,
We don't do ID's we stock the BOSCH injectors which ID then match flow.
Cheers,
Brendan
(VM)
Then why are u advertising id for ?
Many sellers do it.
Riding the coat tail of injector dynamics I suppose .
Edited by Ben C34
  • 1 month later...
Massive clearance on Siemens/VDO metal body injectors - 380cc @ $95/each.
These are getting very rare and no longer manufactured.
  • 1 month later...
G'day mate,
Can I get a price on a set of 6x 1000cc TOP feed High Impedance injectors to suit 11mm Greddy fuel rail on a ECR33 RB25det... inc delivery to Perth.
Cheers.
Edited by Nemesis
G'day mate,
Cheers.
Hi,
Sure thing mate, BOSCH 1000cc injectors (E85) unit's, 11mm o-ring extensions and plugs would be $660 incl. delivery to Perth for the complete set-up.
Let me know,
Brendan
(VM)
  • 3 weeks later...
New 1150cc @ 4 BAR BOSCH injector's in stock now (unmodified)
> E85 compatible
> Improved Spray Pattern
  • 3 months later...
  • 1 month later...
  • 3 weeks later...
Hi mate!
I would go with the BOSCH 1000cc injectors, they are the only unit's which are purpose built for E85 and race fuels.
Price on a full set of 6x flow matched with extensions and plugs would be $660.
Cheers,
Brendan
(VM)
So these 1000cc EV14s are different from the other larger size injectors you offer?
How large do the bosch EV14s go?
Hi,
Sure, the 1000cc injectors are purpose built for use with all fuels including E85.
They are a 3/4 length injector however extensions can be supplied for them as well to make them full length.
Cheers,
Brendan
(VM)
Hi,
Cheers,
Brendan
(VM)
Yea these are the ones that I already have. I am wondering if you have the higher CC EV14s or are these the largest you have of these type of injector?
What are the larger options for R34 GTT?
Can I have a price please on a set of short (40mm) 1000cc top feeds and a rail to suit that will fit under a standard RB25 intake
Cheers
Andrew
Cheers
Andrew
Hi mate,
The only 1000cc inceptors we have are 3/4 length which are a slight longer unit.
Will this be suitable?
Cheers,
Brendan
(VM)
I'll have to do some measurements. but from memory they will foul.
Let me know though.
Do you have a part number for the specific ones you require?
  • 1 month later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
