  • Replies 58
Avoid driving it dude, because lean afrs on cruise can and will burn your exhaust valves.
why would it be lean on cruise? i think your right with any boost it is leaning out, that must be why the light started flashing on mine, or maybe the tune.:whistling:
Here is how the intake was setup when it was stalling.
This is how I had it afterwards to fix the stalling. I'm more convinced it was the ripples in the flex pipe than the extra length and bend, obviously had the air filter on for the test, this was taken before I put it on for the sake of the pic :).
Its the angle the BOV enters, not the bend that causes the stalling imo. It looked like a nice intake until you ditched the airbox. :thumbsup:
I have to agree with scotty here
You can imagine the BOV just venting and bouncing around in all directions disrupting the flow.
When Scotty designed mine it dumps into the intake on an angle towards the turbo
Yet another thread full of mafia's condescending crap, i hope it makes you feel tough :thumbsup:.
Not really hey, I've seen the AFRs after many of these upgrades and I know for a fact that they run lean and its not advisable to drive them far or at all.
So, dribble your shit elsewhere.
I wondered the same thing, but I've seen it on a few cars.
I'm thinking that at 2,500rpm and above the turbo is spooling a tiny bit, making the air path easier into the motor. Being a bigger turbo, its able to help more air into the engine. Think about it, at those revs, the turbine is spinning at a notable speed. The compressor would be "helping" the air get into the engine easier on vacuum, allowing it to breathe easier.
What had been tuned to 14.5 - 14.7 afrs on cruise, I'd seen go above 15. Also caused the engine to run a little hotter at cruise due to being a little leaner.
Not all but a number of cars.
Oh no not a 5% rise in AFR's, how on earth are the exhaust valves going to survive that. Load is determined by the AFM, unless theres a leak or something else isnt working as it should then its fine to drive normally. Sure the AFR's arent always going to be EXACTLY the same as they were before but your not going to kill your motor by driving it around under light load. It takes AFR's upwards of 17-18:1 to do any damage to valves and pistons under light-medium load and you'd know all about it if it was that lean.
i agree to this , the engine seems more powerful even without boosting compared to my old highflow i had, and that is significant , and its odd but i think true... and with cams i find it even more noticable..
Edited by SliverS2
No worries. So you just take your nose out of your ass shove your nose up the exhaust and have a sniff, and go "Yep, shes safe enough, thats about 16:1"
My whole point - Unless you have a wideband you have NFI. So is it worth the risk.
I've also seen cars cruise fine at 17:1 without a miss. Wonder how those exhaust valves are doing.
Who knows. But nah, she'll be right hey. Just spent $6k on a turbo upgrade, its just money. Who gives a f**k about the engine.
Its ok though, my cars will always be safe. And the people that listen to my advice.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
