With DECA in Shepparton coming up on the 5th of May i was wondering on who was heading up
And if you have always thought about it and never made it this is a great entry level motorsport event.
It also a great way to meet up with others may you only know off the forums.
You dont need to be a SAUvic member or own a 300 kw car.
So if you want to have a bit of fun in you car DO IT.
Ya know ya want to..IMPORT MONSTER- SAUvic DECA
We stay here .......ACCOMMODATION
Volonteers..........OFFICIALS
WayneO
https://www.sau.com.au/forums/topic/397062-deca/
Half keen, just wanna know prices to participate and how big the track is etc? Do i need a CAMS license?
Chris
Most of the information you need is in the above IMPORT MONSTER DECA link
But to give you a bit of info
Cost of entry 85 bucks
You will need one of 2 licences.
AASA licence will cost you 50 bucks and you dont need to be a car club member
CAMS licence will set ya back 95 but you will need to be a member of a CAMS affiliated car club.
The DECA complex in Sheppardon is a is a driver training complex so it not a race track like Sandown and such.
It has a very large skidpan and roads inside the complex. We do motorkhana style events on the skidpad and speed runs on the
roads and its all timed like Tarmac Rally. Its heaps of run.
And since its in Shep and its a long drive to and from a lot of people make the call to stay on the Fri/Sat night to
kick back and have a beer or 4 or 5 and talk about the day and cars and such. We also have some of the SAUnsw come down.
So in general its just a great weekend.
Hope this helped and hope to see you up there.
Wayne.
https://www.sau.com.au/forums/topic/397062-deca/#findComment-6305520
I will be coming again!!! Filled out my form then my niece got to it with a texta so will send it off Tuesday now.
Recommend anyone to go guys. I went in my stock 33gtst and had a ball.
Good to see ya coming up again Rhys.
see you up there.
https://www.sau.com.au/forums/topic/397062-deca/#findComment-6306200
Easily the most enjoyable car weekend away.
A couple of us come to the ones that don't clash with NSW events any chance we get.
The guys and girls who run it are fkn legends, don't be afraid to ask anything if you're not sure or if it's your first time.
It's great also in that the stress on the car is minimal (one lap at a time) so that's nothing to worry about, the speeds you do are not silly, you don't need big power to be quick at this-so many times we see the guys with commonly considered "slow" NA cars do heaps better than built GTR's.
It's only $85. Give it a go. Anyone who's been before will agree its great fun and you'll also regret not going to previous ones because they're just addictive.
Keep up the great work organizers and volunteers.
https://www.sau.com.au/forums/topic/397062-deca/#findComment-6307034
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
