With DECA in Shepparton coming up on the 5th of May i was wondering on who was heading up
And if you have always thought about it and never made it this is a great entry level motorsport event.
It also a great way to meet up with others may you only know off the forums.
You dont need to be a SAUvic member or own a 300 kw car.
So if you want to have a bit of fun in you car DO IT.
Ya know ya want to..IMPORT MONSTER- SAUvic DECA
We stay here .......ACCOMMODATION
Volonteers..........OFFICIALS
WayneO
https://www.sau.com.au/forums/topic/397062-deca/
Half keen, just wanna know prices to participate and how big the track is etc? Do i need a CAMS license?
Chris
Most of the information you need is in the above IMPORT MONSTER DECA link
But to give you a bit of info
Cost of entry 85 bucks
You will need one of 2 licences.
AASA licence will cost you 50 bucks and you dont need to be a car club member
CAMS licence will set ya back 95 but you will need to be a member of a CAMS affiliated car club.
The DECA complex in Sheppardon is a is a driver training complex so it not a race track like Sandown and such.
It has a very large skidpan and roads inside the complex. We do motorkhana style events on the skidpad and speed runs on the
roads and its all timed like Tarmac Rally. Its heaps of run.
And since its in Shep and its a long drive to and from a lot of people make the call to stay on the Fri/Sat night to
kick back and have a beer or 4 or 5 and talk about the day and cars and such. We also have some of the SAUnsw come down.
So in general its just a great weekend.
Hope this helped and hope to see you up there.
Wayne.
https://www.sau.com.au/forums/topic/397062-deca/#findComment-6305520
I will be coming again!!! Filled out my form then my niece got to it with a texta so will send it off Tuesday now.
Recommend anyone to go guys. I went in my stock 33gtst and had a ball.
Good to see ya coming up again Rhys.
see you up there.
https://www.sau.com.au/forums/topic/397062-deca/#findComment-6306200
Easily the most enjoyable car weekend away.
A couple of us come to the ones that don't clash with NSW events any chance we get.
The guys and girls who run it are fkn legends, don't be afraid to ask anything if you're not sure or if it's your first time.
It's great also in that the stress on the car is minimal (one lap at a time) so that's nothing to worry about, the speeds you do are not silly, you don't need big power to be quick at this-so many times we see the guys with commonly considered "slow" NA cars do heaps better than built GTR's.
It's only $85. Give it a go. Anyone who's been before will agree its great fun and you'll also regret not going to previous ones because they're just addictive.
Keep up the great work organizers and volunteers.
https://www.sau.com.au/forums/topic/397062-deca/#findComment-6307034
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
