  • Replies 7.5k
Posted Images
"Mate,
PHUMAN's R34 GTT 350kwRw is CraZy!
Rocked up to my formal at the adel convention centre in it and my mate in his youger bros WRX!
Shat all ova da Limos and Hot Rods!!
Hehehe.
One of the best skys in adel i believe!
God i love dat car!!! :>"
To set thing straight i havent seen him "in person" in while, i saw his car few days ago.
There's always got to be a lil cocky smart ass around making gay comments ey  :)
well, my english aren't that good, can u pls tell me which word in yr first post mention about u spot his car ? :D
from
the smart ass
ahhh, mr smart ass aka MAxx
mate i didnt mention it,it was on my mind that day i saw it at cartoys bought bk memories So i decided to tell ya a lil about my experience in it mate but i clearly mentioned it in the after posts sunshine :D
Is that okay with you Fobby Maxx?
Max got called FOBBY!!!! :lol: :lol: :lol:
hope you have a good comeback....
seriously why are is their bitching? like darren said this aint ns.com. is that were you came from shorty_01?
nah
i better stop
bitching with boy still breast feeding by their mum is not my style B)
i start it simply becoz i am too bored in uni :(
p.s. shorty_01, as i said stop, stop!
else it won't take long for Mr.Moderator to send u a warning :P
Friday night down at the bay around 11.26pm to be correct.
was behind a black magna ralliart (wwf345) in my mates na auto silvia..lol. next to the magna was a r33 red wine.
A smile came on my face :)
Green lights both cars took off my mates auto non turbo silvia tried to keep up hahahaha! no luck.
But the Magna killed (by almost full car length) the r33...
the magna had a yellow sigh on da rear windo "baby on board" hahaha!.
But serious i was suprised but the ralliart beating the R33.
Any you other guys see this? it was like the road next to teh watermark.
CraZy
Spotted PCOTY 1 with 5or so r33 skylines at about 3 pm sat arvo headind down past pasedena foodland. i tried to make the bitty driving me follow em but she wouldnt  :D
^^^ quote from ns.com
looks like some of us sau people have been spotted :D
Spotted 4 nissans - 1 black & 1 white R32, 1 Silver R33 and 1 black/dark coloured either silvia or cefiro going through the city at a rather accelerative pace sat. night. and then turning onto Magill road? :D
34 GTR
Silver in colour spotted turning off Bridge Road onto Kings on the way home from work tonight.
Has to have one of the grumbliest sounding skyline exhausts I have ever heard..... except for Drift6's external gate against the Clipsal concrete baracades on Barton Tce a couple years ago.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
