  • Replies 7.5k
Posted Images
i have mentioned this before, i keep seiend a bright orange r32. bn style bumpers and
chrome dished wheels (Drifter look) from woodcroft.
happend to follow this car up south road, and it was a female driver! :)
ild say that wouldve been erins car,
i spotted a primered r32 on south rd with black roof
Spotted a black R34 on Anzac Highway at about 5pm just now. Very sexy looking car!
Also spotted a fake GTR two days ago on West Terrace - a GTR badge on a toyota echo!! It's either that guy bought it himself or dug out from some poor GTR owner. LOL...
I keep seeing a red R31 wagon with the plates "AHHH-31" on my way home from work.
Boring you may say...... but the large front mount intercooler I spy has my interest levels increased.
Anyone know this car?
haha, i spotted a blue VT comodore on the freeway awhile back with a GT-R badge on the boot.. i was not impressed
yeah ive seen those its not a badge as such as more a ghey sticker like a special edition the holden has put out
EDIT
after a little looking found a GT-R commo
http://myholden.com/gall2/main.php?g2_itemId=838
Edited by Madaz
happend to follow this car up south road, and it was a female driver! :(
yeah pulled next to her on South Rd. last week gave her thumbs up she waved and smiled....RESPECT chick with nice 32 aaarrrrrrrr! :P
If it was red with a stealth spoiler then it was more then likely me. Traffic was so slow!!!!!
Yup.. I think it must be you! :P Red calipers and stealth spoiler... So, are the brake calipers stock calipers painted in red or after market? Looks nice thou...
I'll be changing my brake pads soon... So I thought maybe I should paint the calipers since I'll be taking of the wheels anyway.
I was a big fan of red calipers thou... But now that I've seen my neighbour's brembo orange calipers, I think I might paint it orange (if and only if I can get the same orange thou)
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
