Spotted GTST25 today on McIntyre Rd. As for the photographer, I've got a friend who's REALLY good on the camera and has some expensive equipment, if anyone wants to set a date in stone, I can arrange something :laugh:
  • Replies 7.5k
Posted Images
Well when we do think we could go for a pic like the one attached.
Even one with a sunset with generations style....
34GTR, 34GT-T, 34 4Dr, 33GTR, 33Gts-t, 33 4Dr, 32GTR, 32Gts-t, 32 4Dr, 31 GTS, 31 4Dr
Or something similar, maybe along the coast instead, similar to where we took pics at victor.
(which someone can photoshop and make new SAU banner for top of screen perhaps)
Just an idea
***edited*** SAU does not condone street racing, please keep this type of chatter to PMs if you must talk about it - sorry to sound like a Nazi, but it is SAU policy but nice car, hate running on stock boost now that boost controller has crapped out. Alot of difference between 8 and 13 pound lol
would sky lookout give us this sort of look
Where is that? Never been there. If has a long straight lot of parking then yeah, or even if we can have two rows behind each other and take picture from a higher point could see how many lines we can get in the picture.
Heslo can you organise a time or something?
^^i hope that was an evo!! :laugh:
I dunno was definately a turbo tho, would like to see what the difference would be if i was running higher boost, currently im running about 170-180rwkw so i can notice the difference from the 200+ i had with the boost controller
Edited by gts33t
All the best for Bill..
Thanks for the update. :laugh:
Where is that? Never been there. If has a long straight lot of parking then yeah,...
sorry its spelt skye and its @ the top of kensington road it will get bussy fri sat and maybee sunday night and got no idea if we would get that sort of photo but i know there used to be a vantage type point right behind
maybee mt lofty is worth looking into
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
