Heh, was thinking it was someone from here, nice car buddy! Did ya get the front bar as a Chrissy present?
cheers mate nah just havnt got round to getn it painted should be getting it done start of january then should look alot nicer lol yours looked like a pretty tidy line :nyaanyaa:
  • Replies 7.5k
Posted Images
seing that we are on the topic of stolen cars id like to add my old vl turbo was stoilen out of a freinds drive way.heres a couple pics.
How long ago was this? I know alot of people who drive VL Turbo's (i.e. MR VLT) and the likes, therefore if anyone was to see it around these guys would notice it for every detail. What area would this be in approximately?
Spotted a guy kick a black r33 in the balls on the corner of Waterloo Cnr & Whites road around 1330ish. Try harder next time, k? I know that car can do better then that. :D
spotted leeman (i think) comin out of munno at about 5:15, i was in the red magna at the round about gawking :P
Yeah that was me , should have beeped at me or somethin! Did you end up getting a ride for friday night? Sorry i cant take ya, im going to take my boy along for the cruise!
looks farkin sweet as man! great work :iluvff:
haha, i can imagine the :P look if a tool in a magna of all things beeped at ya :)
still havent got a ride, but i might be able to organise something, so all is good.
Hah, thanks vrfour! :happy: She was dirty though, looks a lot better now however. Think I spotted you a couple of nights back zipping past the school near my joint. If it wasn't you, it was another 34 that looked identical
quote from ns.com spotted thread -
"seen a nice skyline with the plates vange with a hot chick driving it down anzac on friday night"
ha ha ha
say it aint so
HAHAHAHAHAHAHAH as if som1 saw me....
i let 1 of my friends drive it down anzac....she was very lucky...and i was hotter than the chick, as if they didnt c me HAHA
followed a silver r33 down the top of greenhill road about 3am this morning, had custom plates 33 g k or something similar, nice car
thats a mate od mine, his plate is GR 33 K as in greek and he has a R33 lol.
Edited by vange
