  • Replies 7.5k
Posted Images
ummm spotted so many the last few days, i cant remember. but why when i give people a wave or even a thumbs up they kinda just look at me like 'WTF'? :D
One i DO remember is a glittery purple-ish 32 with BN/Vertex kit, looked shiny as, new paint job it seems. On Montague road yesterday bout 4ish.
Spotted a nice Gunmetal Gray R33 on South Rd, followed it from Port Rd to Sir Don Rd at 8am on the way to work this morning very nice exhaust on it
Edited by Da_Black_Wolf
ummm spotted so many the last few days, i cant remember. but why when i give people a wave or even a thumbs up they kinda just look at me like 'WTF'? :(
If its a 4 Door, its my mates car just got it resprayed. The job cost more than the value of his car (4 Door non turbo auto 32) :(
If its a 4 Door, its my mates car just got it resprayed. The job cost more than the value of his car (4 Door non turbo auto 32) :P
Umm i cant honestly remember if it was a 4 door. My friend was telling me to stop drooling and pay attention to where i was driving instead of staring at the other car.
KISIN - funny that lol. cos thats probly exactly what i would have said.
last night spotted red 32 with unpainted front bar at subway aberfoyle pk.
today spotted white 32 black bonnet on flagstaff rd, and then a blue 33 with gold rims showing me why cops like to pull us over, wasnt impressed mate i have a skyline too
Spotted a 32 [MISS 32] plates, turning on to Main North Rd from Kings Rd @ 8:30am, and moments later giving her 32 a refreshment of fuel.
I was in the work van the next lane over. Tried to catch up to give a wave, wasn't going to happen. hahaha :)
Was it a white 33? Seen one at carpark in town with both front and back badges, even has the gts-t on boot, should leave him a note 'not a GTR get over it loser' :D
Edited by gts33t
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
