  • Replies 7.5k
Posted Images
Lol well I spotted a dude that looked like PK in a silver 33 with SAU sticker on the back.
Also spotted a black 32 parked on Currie with vertex rear bar and skirts also with SAU sticker plus a yellow 33 GTR driving along Currie.
Yeah on Main North Rd just before Munno. I love my deeep dishes :O
You caught me off guard thats the first time I've seen a Stagea in person. Very nice car, I do like'em :(
Yeah i tend to get some interesting looks in the stagea huh! I get my black one today back too i think, freshly rebuilt so i have to drive it like a granny but ill still have that sweet rb26 note coming from it!
Also spotted another RS4 on the way home last night, suprised no one spotted two white RS4's driving down main north next to each other!
Seen Serty1 out the front of Boostworx while i was dropping off my brother and the likes to pick up his car. Had a little chat with Troy (like whole 30 seconds) before leaving. I was in the white Skyline that pulled up at the end of the day.
just rolled down henly beach road with ''BOWDOWN'' damn that's a nice car! had a bit of a chat along the way, thing sounds nuts on boost :P earlier saw a black 32GTR on military road doin laps around a round about :D and a few lines down the bay this ARVO..
Spoted a white R34 2 door with white rims (maybe TE37s ? - only saw it REAL quick) infront of West End Brew. and also a "pinky-ish" supra, plates HARDY on South road tonight.
Anyone know anythng about the supra ? What power etc ?
Edited by KISIN
^^^ Seen that around a few times & it has a pink'ish base chameleon paint. The times I've seen it out cruising it looks like more was spent on the paint & aesthetics than performance but, could be wrong & maybe it wasn't boosting that much :P. Why you ask?
yeah i think the silver 33 with the sau sticker would have been me..(damn i was really running late for work) :D
^^^ Nope not me....well I hope it wasn't my car :P
;) ...hehe.. chillax patrick!! dont worry mate it wasnt ur car. :)
the black 32 parked on currie with gtr front bar and full bn kit also with the SAU sticker is probably my mate. hes on here as well.
cheers
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
