  • Replies 7.5k
Posted Images
Spotted GRIM R32 in his Black Stagea on my way home today, around 5:30pm. Love the sound of that beast! :rolleyes:
Hey Dave! That was me! Running in rwd too! Was being tuned but they only got half way thru so i got to take it home last night! Lets just say its a little bit different to drive that way! :D
When and where, there's a possibility it might have been me, although I'm not sure I'd describe my car as "nice".
was a 2door man along the road from ingle farm k-mart
im hearin ya :thumbsup:, did you enter into the PGA dyno day @ Graham Wests
still havent seen ya car deluxe, even tho we is just round the corner from ya.........maybe i should come by one day and look hehehehe
Yeh i havn't been past your work at the right time to see yours either lately! Always see Slim Jims(think its his) 32 GTR up the street, and that white 33 up the street from your work! and i think there is a guy that works at Philmac that has a black 33 also, bit of a stocker, but a line none the less!
car has only been in 2 days this week, was broken for the last week and a bit. always see the GTR tho as thats the way we head out to our jobs. i try and park by the fence but cant get there early enuf haha
Spotted Leeman this morning at about 7:50am on my way to work. Gave a thumbs up.
G'day Dave, Seen ya couple of times in the truck in the morning, this time you seemed much more awake :laughing-smiley-014:
lol if youve seen my car (dont think you have lol) youve seen his car hahaha minus those rims im getting off him
spotted a silver 4 door 34 at ttp last night bout 6ish. SAU sticker on the back window. Now i know the car, just cant remember whos it is! Myself and friend in his gtr parked next to it, so just had to take a photo. Was also a dark blue/black stocky lookin 32 parked in front of me.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
