  • Replies 7.5k
Posted Images
spotted 3 33s in about 5mins today
33 4 door on frome road, then turned onto north tce and went past the RAH.
white 33 GTR with gold volk gt-c's goin down frome across rundle
maroon 33 non turbo with silver stripe goin down pulteney across rundle
for all those spots i was in the white Hino ex-ETSA truck with ER on the doors
and an odd spot, i feel like a stalker. Seen Hotwire's missus' SP23 3 nights this week.
Monday night, bit before 6- South / Flaggy. was taking off from the lights (i was heading city bound, she was goin the other way)
Wednesday night, same time, same place - except ya was in the car drivin this time :D
And tonight, parked at marion...........as it seemed half of adelaide was LOL
spotted a white r34 on south rd as i was coming home from work bout an hour ago
oh and got a wave from a guy in a 180 this morning..................waved back............he then wanted to take me on...i just ignored it and he ended by flying off by himself
Edited by MissR34
Wednesday night, same time, same place - except ya was in the car drivin this time :P
Bloody Stalker :D
Surprised you didnt see me monday night then, I flew through the lights in the 33 just ahead of Brooke ;)
You'll probably spot me in the SP23 most nights actually, only drive the skyline once or twice a week now. SP is good on petrol and I just drop Brooke at work and pick her up.
Still haven't seen you in your ute though.. need to look harder I think!
wont be hard to spot a big grey primer patch on the bonnet of a red ute LOL.............right where the holden badge should be
Was driving next to Maxx 90% the length of Anzac Hwy then Morphett Rd thursday night (was in the SP23).
Also, keep seeing purple 40th anniversary skyline in melrose park.... looks hot every time I see it, has some 18" 5 spoke rims with a little dish too :whistling:
spotted a nice looking wine red 33 leaving ttp had ztecs on the back
also spotted a panda ceffy near the plaza very hot
saw a silver r34 fronted 33 near jb hifi at modbury
and lastly followed a gunmetal grey r32 gtr past the plaza
oh yeh and saw flicks car at bob janes
saw a white 33 going past bunnings on nth east rd modbury, plates were ** 2500, had a sau sticker on the rear and front, we were the ones standing on side of the road waving :)
I was 2 lanes over when you turned off Magill in my EXTREMELY dirty 33 i was out looking at imports for my mate (Gallant VR4 - Aristo) just sitting talking about the blue parkers when you came up and went past it was freaky timing
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
