  • Replies 7.5k
Posted Images
Spotted this morning bout 7-ish, Matty in the daily going down south road, didnt realize it was you til i saw the SAU sticker on the rear quarter window, then it was to late to wave, saw you wave but. :(
Also on my way home spotted either a dark blue (like mine) or black R32 GTR going north down south road near the shops in o'halloran hill, stuck my arm out the window and waved but dont think you saw me.. Car looked very nice.
took a chance it was you, always wave at random gtr's LOL
last nite spoke to the guy who spotted me at the on the run (sorry mate, keep forgettin ya forum name). man, anyone who was out last nite will know it was a fun nite LOL
spotted Nightcrawler drive past us in kmart carpark last night after BDO, cheers for coming back to say hello :(
haha yeah was going to post today about spotting Flick and Luke (ex NOT URS) at Anzac Dragway BigW. I was cruising past with 2 crazy S15s (one white with black rims, the other blue with chrome-lipped black rims with P plates) egging me on to race - before they took off at 150km+ down South Road.
There were soooooo many boy street racers out last night down Gleneg direction after Big Day Out - it was quite crazy. And not a cop to be seen where I went.
Also spotted gzilla giving out suncreen at BDO - nice work mate. Sorry I didn't hang around to chat - was pretty wasted by that stage and trying to keep up with a mate who wandered off.
spotted driving past the mile end hotel (Was in the Bottle-o buying a carton of coopers finest) Bayside Blue R34 GTR, Standard slimline plates, Bronze Work XD-9's, twin cannons.... VERY nice car man. :(:huh::(
Say what? Ex not urs? :(
hey steve, whereabouts did u see me?>
on my way home from adelaide pro sound (and george did did an absolute amazing job of my parcel shelf.......thank you soo much)
RBB033....got a wave and wavd back
Silver r34 gtr on south rd, was being driven by a girl
Pete (Sled) on west tce(?) in his little truck!
red r34 on main north rd, waved and got the wtf look.........was quite funny to see the look on the guys face
Saw last night RB25DET (Red R33) parked on Jetty road, forget the time, must say very nice looking car, nice rims, bronze goes well with the red :banana:
Edited by GTR-32
Yeah it was good to have little chats everytime we stopped at lights......your car looks great out on the road Cara.
So......another silver R34 GTR (female driver) out on the road........would be good to catch up and compare notes.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
