http://www.ebay.com.au/itm/140735515924?ssPageName=STRK:MEBIDX:IT&_trksid=p3984.m1426.l2649
Listed on E-bay as a GTS-R is an November 1987, with model code KRR31RHFSM GR i was under the impression GTS-R's were KHR31, and GTS / GTS-X were KRR31. (i may be wrong - Fatz R31Nismoid would know).
Has all of the GTS-R options. ie. interrior, aircon, turbo, manifold & heatshield, RB20DET-R Engine, Impul ECU, Genuine bodykit etc. The guy sent me the vin to FAST and it was genuine colour etc, but did not come up as a special model etc.
Is it a replica or possible that it was spec'd with GTS-R options? or the Real Deal?
Been looking for one for a while as stock as posible, but don't want to pay an overinflated price if it isn't the real deal.
I am not an expert on GTS-R's just curious. The guy that owns it is certain that it is genuine. (as you'd expect)
I was looking at that too
no idea if it is the real deal or not
and given I have nfi whaty they are worth I didnt put a bid on, sounds like it needs a bit of work
So my question is - what is a decent standard GTS-R worth these days?
Aside from wheels and exhaust tip it looks genuine. Try on R31 skyline club. Might be someone on there selling it and you might get more history on it if it's been in the country a while. Genuine ones can go for 17k + depending on condition of course
Edited by FordyR31
yea i asked this dude for more picks(which i am stil waiting on)
thing it appears to be missing are rims, exhaust seats
which are key if you want a gtsr
its never been registered before, and has enough rust to not make it roadworthy and the paint is shit
whats it worth? 8k i recon but its already over that (no rego, no roady, rust, shit paint) but the marked has alredy overpiced it i recon
16j will get you a orginal with average paint
20k will get you a nice one
25-30k will get you a sweet one with low km
fast wont tell you if its a gtsr from what i have seen ( i have fasted several and they dont come up as a gtsr... or i have just looked at replicas)
nice car i would buy it but the price is too high
You cannot tell from the outside if it's genuine or not.
A shot of the engine bay is the fastest way as a GTS-R has a totally different A/C set-up to other HR31s. Almost impossible to replicate without being obvious, you'd have to buy a complete A/C off a wrecked one. So ask for a few shots of the bay.
FAST doesn't tell you as Pete said, you can send an email to R31House/Shibata San. The language barrier can be a bit of a problem haha.
Depends where the rust is in the rear, and how much there is. I'd also say there would be rust in behind the front guards and the chassis if the rear has rust. It's quite common as leaves/dirt block up the drainage over time.
Drivers seat looks like something after market with a cover over it. Funnily enough I have a second seat of GTS-R driver/passenger seats :)
Agree with pricing.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
