No new graphs mate, I really should get one, LOL.
When I get my fuel system sorted (was >75% duty at 414 I think from memory) and run 30psi through the TO4Z Ill get one to post up.
Maybe next year
They have taken a fair amount of material out around the valves!
I spose because they are 1.5 mm OS. The head was originally modified for the 1.0's. After it came back from NAPREC Hiroyuki took out a bee's dick more for the extra 0.5mm.
See how it goes eh?
Crank and pistons dropped off this arvo. That should not take too long. Head is less than a week away. Double check CR. Going by my calculations a 1.2 mm headgasket will bring it to 8.5:1.
whats the deck height? Are you aiming for a tight squish for this motor?
Block hasn't been decked at all. Head has been decked 1.0 mm at NAPREC. We just have to get the head here and take some measurements. From what I can gather the chamber volume is 66.5cc but that's got to be double checked.
Not sure if you have read my thread if not please do so as there is alot of info about squish and its advantages
I remember something about a 33 thou squish. How does this change when one of the pads have been removed?
i guess they have taken the intake squish pad out so you can still set the squish with the one pad all it means it will push the air and fuel towards the intake as this will be the cooler side of the chamber. If your looking at running big boost, this will help it from detonation
Update here, doing it for Paul cause the pics were taken on my phone.
First is dropped all this stuff to Chris at Craved Coatings (look them up, really good work and very reasonable prices) for ceramic coating. This will be back in 2 weeks;
Next we went to where Marcus had sent the head (Unigroup), this is the first time it's been seen and has only been in the country a few days.
Typical Marcus wrapping, it's bombproof!
Awesome that he left the flight stickers on - Marcus brought it back as carry on luggage on the plane haha!!!
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
