Haven't rang Yavuz yet. Been too busy with work.
I did drop the rear by 5 mm. What's the "optimal height" for handling on a R 33? From looking around it seems to be 350 -355 from centre of wheel to the guard. Is that correct? Sits pretty high if it is!!!
Still the twins or have you gone to single?
Still the "pussy" twins ATM. The 6466 is still being used as a paper weight out at Unigroup. I should take that home one day!
Should strap it to the side of the motor not take it home!
One day. I don't want to spend anymore money on the stupid thing for a while. I'd like to low mount it too (if possible) so that will mean some stupid custom manifold. Ive spoken to Hypertune already about it and they were keen to sort it out.
