I don't really like 33's that much. But the 33 GTR is such a different beast, i love them! This is an almost perfect example of how to do things right. I have been following for a while and it's all been very interesting, but needs more videos! :P
I have a few, but not too keen on putting "silly" stuff up of on the street. :(
I know.
I have one, just needs to be sorted in black. Same colour is homo!
Make sure you get brake ducts while you're at it.
S2/3 are different, which I'm sure you know.
Can't get much easier than that! haha
Tell me thats not a zip tie of the fuel pump outlet 90deg fitting??? I'll cry if it is :-( aaaaaahhhhhh nnnoooooooo!!!! ha ha ha.
Otherwise, nice pig ;-)
Paul , looking like porn underneath the beast. No flash and sparkle just the goods that make it go round corners like a go-kart and brown stains the passenger seat.
Maybe you should get your arse over to ping pong land for Nismo Festival and I'll hep you get nice new black lip for half of what Nissan cut you a new ring hole charge, plus have a week of non stop drinking and eating sushi of the backs of naked candy girls.
Might be stupid question, but is the reason the exhaust goes back into one pipe and splits off again due to clearance?
Oh and great build by the way, fantastic.
Yeah mang. This exhaust was originally made for the owner of Racepace for his own car years ago. Just don't have the space to fit two 3inch pipes beside the diff.
Thanks mate. Looks really well made too. Again congrats on the build.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
