7 minutes ago, ActionDan said:
But.. how can we agree on something? I run a Haltech that fits into my kick panel.
#theshame
No Peter loves living dangerously like you and runs a haltech without a crank trigger.
2 minutes ago, ActionDan said:
You should get Emtron, it will double your power instantly.
Don't be silly, you know that any ECU can make power, its how it behaves everyday and weather it delivers on the features it's marketed with.
Anyway looks like Piggaz cheaped out and bought a knock off Motec m150....
So somehow the ECU is the issue, not the old CAS, and moving to a superior crank trigger setup is the fix, but we blame the ECU?
Sounds backwards?
Wait? I've got it! Its because the signal has to travel through so many boxes and so many wires!
Sounds backwards?
See now you are starting to get it...
The old powerFC, Nistune and adaptronic don't suffer from issues... unless of course the loom is cooked or the CAS is actually faulty..
I bet all cases of timing related issue are definitely tested properly as being the ECU for sure.
So how much better does your car run since switching?
They are actually, but let's not get the facts in the way of things. As long as you are happy with your car that's all that matters!
Lol if your in vic go for a drive in Andrews car
next day you will rip out haltech and put a power fc in and have a retune with the bloke who sorts his car
100% garentee that
2 hours ago, ActionDan said:
How much better is your car to drive now you've switched from Haltech to Emtron anyway, must have been a massive improvement?
Bit weird Mick, you thought the Haltech was decent a few months ago? What happened?
"Hey guys up for grabs is a Haltech elite 2500 with a patch loom by haltech to suit an R34 GTR. ECU has only been in the car for around 10000km max im sure anybody shopping around knows the capabilities of this top of the line ECU. $2800ono"
I guess top of line doesn't actually mean it's any good I suppose. Soi I reckon the improvement must be massive and dyno proven with no other changes to skew results...
Lol i sold that POS on behalf of a friend. I never thought it was good as it never remembered the tune properly mate.
Sadly that wasn't a bad thing because the tune was as bad as the ECU ?
I wasn't going to offer my ACTUAL opinion on that when i was trying to sell it haha ?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
