5 minutes ago, fatz said:
Was fast and reliabe was its problem
no heart they are for people who can't drive... anyone could drive it fast and they make you look good at the track
much prefer to be taming a beast and semi out of control most of the time... eg a challenge
Fast and reliable sounds fantastic,
but don't like the idea of it practically driving itself makes it sound boring and being auto would make it even worse
1 minute ago, ActionDan said:
Lol this car is too fast and doesn't break often enough, SELL IT
Exactly ... junk
plus the people it attracted were special
bow I'll just get people saying purple gtr sick bro what does it do on the quarter
 shall tell them 8.59 kebabs a hour
  • Like 2
Otherwise this thread may end up like this .....
Again....
Here is a video of Fatz's car from the previous owner. He now assures us the ECU is now secured with some garlic sauce.
lol f**king ECU just sliding about.
GT-R makes no sense as a track car, S-Chassis is where it's at.
No bullshit AWD, better on brakes, tyres, heat management, cheaper panels lol
True but luckily all those issues are well documented and sorted so they are a non event.
Fitting week to post this.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
