  • Replies 179
I managed back to back 12.35 passes with 40hp less and 19inch rims with streched 245 rubber. Going back with more power over the entire rev range and 18s with much better 265s, so i am confident of high to mid 11 second passes.
How did you go with traction with the 19's?
I run the same tyre with less power approx 270awkw and had wheel spin all thru 1st gear....rs4s
car was to low as well, too much neg camber as well
My setup was similar at the time around 270kW, 3ish deg neg camber and impractically low. I let a heap of air out and traction was pretty touchy, my first run was all wheel spin and limiter bashing.
I got my best times with 6500ish RPM launches and plenty of clutch slip to keep wheel spin to a minimum.
Edited by numleg
In reply Rudi, I still have no front shafts in the car atm- its RWD. I want to get it back on the dyno, so I really cbf getting it in and out just to do some drags.
Plus I think that Craig and I are going on the same night for the lolz. Craig needs a tune first. He wants to stick it up the Mexicans.
I love how you rounded it off to just me Alex! ;p
Need to practice my stall launches.....20psi and 4wd for the win! :P
I may be able to get the same response now, the .82 on the new GTX3076 is in and it feels much better than the old 1.06. :)
Boost at stall would be nice... :)
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
