  • Replies 179
I managed back to back 12.35 passes with 40hp less and 19inch rims with streched 245 rubber. Going back with more power over the entire rev range and 18s with much better 265s, so i am confident of high to mid 11 second passes.
How did you go with traction with the 19's?
I run the same tyre with less power approx 270awkw and had wheel spin all thru 1st gear....rs4s
car was to low as well, too much neg camber as well
My setup was similar at the time around 270kW, 3ish deg neg camber and impractically low. I let a heap of air out and traction was pretty touchy, my first run was all wheel spin and limiter bashing.
I got my best times with 6500ish RPM launches and plenty of clutch slip to keep wheel spin to a minimum.
Edited by numleg
In reply Rudi, I still have no front shafts in the car atm- its RWD. I want to get it back on the dyno, so I really cbf getting it in and out just to do some drags.
Plus I think that Craig and I are going on the same night for the lolz. Craig needs a tune first. He wants to stick it up the Mexicans.
I love how you rounded it off to just me Alex! ;p
Need to practice my stall launches.....20psi and 4wd for the win! :P
I may be able to get the same response now, the .82 on the new GTX3076 is in and it feels much better than the old 1.06. :)
Boost at stall would be nice... :)
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
