I've finally decided to start with the cat back on my 33 GT-R - later on I'll finish it off with the Blitz front pipes and the Catco 3" cat.
I'm after something that will sound decent but not too loud. I do trackdays so definitely don't want something that will get me chucked out for being too loud.
What do people suggest between these two choices.
Any feedback is appreciated.
Neither. Get a custom job done. Won't be much more and the results will be alot better.
Can you please elaborate why would the results be better.
Few local guys i spoke to just offer x-force 3.5" setup - please recommend and exhaust place for a custom job
What's the budget?
Most jap systems have the '90 mm piping'... But have their crap 2.5 inch 'muffler' down the back!
I'd never buy a jap system again!
None of the jap systems will be over track noise limits. You'll be fine.
Racespace or Rob Sabbadin will be able to do a custom system for similar price i would image. Call em.
Imo there is little difference between the two u have mentioned. HKS has a nice note on GTST.
Disagree man.
The kakimoto on my car sounded like it had venting to atmo gates on it and in the end held the car back! FKN GARBAGE!
Custom job will cost about $400 more, easily.
You can't go wrong with either of the exhausts you've chosen, it's which one you like the look of more. I'd go the Blitz RX
Either of those choices are a waste of time without the rest of the system. Do dumps, front pipes, cat THEN cat back at the same time.
FYI I have dumps to tip all for sale soon. Has flown over 400rwkw.
Also swap turbos, ecu, injectors, fuel pump, build engine, add twin plate clutch-those are all things btw that have been covered on sau time and time again.
Depends if the person is a "shop by quality/result" or "shop by price".
What's the budget?
hmm - din't know that - when I saw 95mm piping on the HKS I simply assumed its all the way through.
Cool - calling dibs on that system - since that's the end game for me anyway.
Could you pm me some details.
The HKS for R33 is 95mm, but it tapers.
It starts at 3inch from the cat, hits the little hotdog muffler and goes up to 3.5 inch, then after the flange for the cannon it steps up again to 3.75inch.
Its the second exhaust i have owned thats done this. My old Mugen Twinloop exhaust on my ITR did the same thing.
I have the HKS on mine still with a GT30. For the street is a little loud, so have built a replacement middle section with another muffler for the road.
Heres the HKS Vs Apexi. Sorry the pic is a bit small, but you can kinda see the tapers, and that it is substantially larger than the apexi.
Another classic example of the Jap systems doing this 'taper up and down' rubbish.
My kakimoto - Full Mega N1 started off at 80 mm after the cat, into a muffler then up to 90mm then into the rear muffler which had an internal diameter of 63.5mm (or 2.5 inch). Absolute crap. Live and learn!
r33 rb25det 3" front and high flow cat, Hks silent hi power 102.9db at 4500rpm from 1 metre, not quiet like i was told.
also i have plans to do track days and i don't think it would get you kicked out, sounds mean on throttle :)
Edited by Stevoss
mine doesnt taper down. just up. and it hurts the power zero.
Have you looked inside to confirm?
They often have internal baffles, most of the Jap ones I've seen come through have them. Both my jap ones over the years have.
"3.5" exhaust, but with internal baffles around the 3"-2.75"
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
