Hey S.au need help with my gtr -__-
car runs like a shitbox especially when is warmed up!
car will miss and broad minded personter and wont rev past 2,600 feels like its a tune issue .. not a coilpack miss or spark miss but an electronic part shit itself f**king my shit up
had issues with air flow meter ... when it was warmed up 1 AFM was causing it to stall when hot ... replaced the faulty AFM now just runs shit house but runs -__-
timing has been checked .. throttle position sensor doesnt cause survere symtoms im having .. coolant temp sensor was recently replaced (ecu type)
any1 have ideas on what would cause this ?
any1 know any good import mechanics preferably with scan tester in brisbane southside?
cheers S.au f**k piggs!!!
https://www.sau.com.au/forums/topic/397906-engine-problem-with-rb26-r32-gtr/
car doesnt shake heavily .. although it could possibly be 1 cylinder down =/ or head gasket issue ( hope not though ) dont have comp tester or TK tester
hope its just some sort of sensor fault ... ecu shit itself ? common problem =/ ???
I've got Nissan data scan and I live in Ipswich/work at Richlands if you would like to see if the self diagnostic has anything to say.
diagnostic scanner would be choice !! when are you free ? would be much appreciated!!
It still sounds like an AFM issue. Do u have 2 known working ones u can borrow off a mate or sau friend.
Where are u located
Southside brisbane Forestlake
originally had AFM issue .. 1 was causing it to stall .. replaced that 1 and it stopped stalling ... but runs like shit =/
when i change the other AFM with the 'faulty' 1 .. car stalls again *thinks* dam 26s
  • 1 month later...
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
